LM 3886 bridged - Page 2 - diyAudio
Old 14th January 2006, 03:52 PM   #11
nobody made this amp yet?
Bass maniac
Old 14th January 2006, 04:20 PM   #12
veteran is offline veteran  Poland
veteran's Avatar
Why not use a parallel configuration of two LM3886 or one LM4780 amp? No phase inversion needed and it can easily drive less then 8R speakers.
LM4780 stereo/parallel
Simple audio solutions
blog.unisonus.com
Old 14th January 2006, 04:51 PM   #13
i need min 100W(max 200W) into 6-7ohm load(real values)
Bass maniac
Old 14th January 2006, 05:03 PM   #14
veteran's Avatar
Theoretically You should get 'real' 100W on 6R using this configuration of chip-amp. But if You wont more power - look for some discreet bipolar or mosfet amplifier.
blog.unisonus.com
Old 14th January 2006, 05:05 PM   #15
XELB is offline XELB  Portugal
Originally posted by -_nando-_
NEVER drive loads bellow 8 Ohms with 3886 bridged !
I am driving 6 Ohms speakers with LM3886 bridged and they don't get very hot
My trafo is 20-0-20 .....
BTW, the LM3886 plays very well when it's hot
If you want power you must add control
Old 14th January 2006, 05:09 PM   #16
using +/-30V results 160Winto8Ohm load(using theOverture_Design_Guide13)
so i was hoping at least 120W
Bass maniac
Old 14th January 2006, 07:10 PM   #17
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
Bridged amp will drive a load of 4 ohms , but the protection will not allow to reach the highest power levels.
To get 160 w RMS you will have to keep ur chip temperatores low.That means a large heatsink , and a fan. I think it is better to use 4 chips instead , and have 200 w RMS without a fan.
Did you read BPA - 200 app note ?
Old 14th January 2006, 07:49 PM   #18
i want to use just 2 chips,and i don`t intend to use 160W;100,at most 120W;although the speakers i`ll use are rated at 200W RMS
Bass maniac
Old 14th January 2006, 08:11 PM   #19
veteran's Avatar
So You don't have a choice Use both of them in parallel configuration.
blog.unisonus.com
Old 14th January 2006, 08:37 PM   #20
i only have 4 chips for a stereo amp,in paralel,they don`t give 100W/8ohm;i`ll stick with the bridge config;with a power supply of +/-30V
Bass maniac
Using +/-70V on a LM 3886 Pery Chip Amps 17 23rd July 2007 10:58 PM
pre amp for 3886 bostonswoop Chip Amps 6 19th June 2006 03:58 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 07:51 AM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 07:53 PM
PCBs for stereo bridged 3886 soundNERD Chip Amps 12 15th December 2003 08:39 AM
Copyright 1999-2017 diyAudio
