LM 3886 Tips...
I MADE the amp !
I made two 3886s, and I did some modifications in the original schematic from PDF.
The 20K feedback resistor, I replaced with a 22K one, and Ci I didn't put, Ri I replaced with 680Ohms resistor.
The Imput I replaced the 1K resistor, with a Foxconn 4,7uF 50v capacitor, with a 22K resistor to the ground.
It all was based in this:
http://dogbreath.de/Chipamps/GainCardCopy/GainCardCopy.html
And it realy sound better than the original diagram from the PDF :cool:
THE SOUND IS GREAT !!!!!!!!!!!!!!!!!!!!!! :D :D
I'm running two 3886s with two 5.000uF 50v Siemens caps, with four 20W 4Ohms speakers, that is 8Ohms 40W for each channel :)
These are the speakers:
http://www.bravox.com.br/produtos/caixaacustica_mini35.asp
REALY good speakers, I don't know if it's avaliable in your contry :clown:
Next step is build a c200 power amp, the elliot's 2 way crossover (centered in 300Hz), and the subwoofer box.
Sealed, vented or Band Pass for sub?
BandPass I think is impratical for a 12 inch subwoofer ahahahah :eek: Imagine the size of the thig HOHOHOHO :bfold: So, It's OUT.
The question is... SEALED or VENTED??? :scratch:
I know (but I don't know if it's right) that vented can reproduce lower frequences better, and more extended and smoother bass...
But it will run in a dinner room that isn't small... Which one is the best for this application?
Waiting feedback ! :D
I don't want hard bass and high SPL...
I want smooth and extended bass, good for ears... But I want it without distortion, that's why I choiced s 12 inch subwoofer, then I can put it in low volume and have the bass that I want.
I want the most plain frequency response possible, and good reproduction of lower bass, like 20 ~ 40hz. But I'll cut the subwoofer at 300Hz, and the speakers will play 300hz ahead.
I want Sound Quality, not SOUND PRESSURE
Which one do you think is the better for me? Vented or Sealed subwoofer box? The room isn't small, but isn't that big too ;)
Thanks ! I contacted the subwoofer manufacturer, and he will project the box, then I just build it with care! :)
But, one problem with 3886s... They are receiving FM RADIO STATION :bigeyes: HAhah... What do I do to minimize this?
Other thing... They are operating with 8Ohms 40W 30+30v, and heating too fast, and not a lot, but enough to worry me ! Are they like this?
Sound is PERFECT, it sounds veeery good indeed ! :D
The Heatsink isn't that big... medium, not small... But the load is light and supply is ok ! The supply do not heat :whazzat:
Maybe the feedback (22K) resistor and the Ri (680ohms) with Ci ommited makes the chip generate heat? These values and parts are based on 47labs amplifier (gaincard).
When I turn it on with no imput signal, it get WARM, and I think it should be in the ambience temperature, is it right?
Occasionally, current in the output leads (which function as
antennas) can be coupled through the air to the amplifier
input, resulting in high-frequency oscillation. This normally
happens when the source impedance is high or the input
leads are long. The problem can be eliminated by placing a
small capacitor, CC, (on the order of 50 pF to 500 pF) across
the LM3886 input terminals. Refer to the External Components
Description section relating to component interaction
with Cf. ... from datasheet
You may also want to keep input leads short and twisted.
and try to bypass your caps to the power pins with 0.1uf ceramics or poylprops, if those are too expensive...
Yes, they heat up pretty quick, but should not get too hot, providing you have adequate heatsinking.
With no input it should not realy get warm, so it may be oscilating... Have you measured DC on the outputs yet?
How close are your caps to the power pins? how long are your speaker cables?
The datasheet loves the parallel 10R resistor and 0.7uh inductor on the output, I think this helps especialy for cases of the oscilation fever.
The LM3886 consumes energy even when it is idling (as do most non-switching amplifiers) -- if you go to the National Semiconductor website you will find an interactive search engine which will tell you the thermal impedance of heat sink required as a function of the power supply voltage. http://www.national.com/appinfo/audio/files/Overture_Design_Guide15.xls
From the thermal impedance (theta) you can back out the size of the heatsink required. In this case theta should be ~4.1 Use 32 LFM for air velocity and play with this tool:
http://www.aavidthermalloy.com/technical/thermal.shtml
Radio reception can generally be curbed by placing a 200pf capacitor across the input terminals -- although this is the first time I have heard of FM interference.
Jack
FINISHIED the 3886's PCB ! :D :D :D
I soldered the parts at the back, because of the heatsink !
As everybody says that it's a huge 10A device, I made large connections on the board !
I tested it today, and all old problems were solved, no more RF interference and heat. I think it was heating because of oscilation, as the Nordic said ! Now it's much more cold.
Two 0,1uF 250V polyester caps were added between supply rails and the ground. And in the imput I added one 100pF to the ground, and finaly at the output, I added the 0,7uH with 10R resistor, to prevent oscilation :)
Everything is fine and cold now ! :D
Thanks to ALL OF YOU that helped me to solve those problems !
And I'm still waiting for feedback ! :cool:
