| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I'm having a bit of an issue with an lm3886 amp I just built(using the amp kit from www.chipamp.com). When I crank the volume into excessive levels the sound on one of my channels cuts out for about 2 seconds and comes back in and does this every so often, it's very random, and occurs alot. I'm using a CPU heatsink, which from what I've read is adequate for this amp. This problem is just for 1 channel, the other channel stays on. At first I thought something may have been loose in the speakers and amp, but everything is pretty secure and connected. So it does'nt seem to be anything intermittent. Has anyone else had this issue? I'm thinking it maybe heat because the chips do get warm, but then would'nt both channels cut out? I'm seriously considering rebuilding it, which might be the only choice I have if I can't figure this out. |
#2 |
i would work on the mute section area....
#3 |
is it the isolated or non isolated 3886?
#4 |
Sorry? but I'm not familiar with isolated and non isolated. If I had to guess, I think you'd mean is it seperate from the power supply? which it's not, it's all housed in the same chassis. I'm not sure what the mute section are is either, sorry for my bit of ignorance.
#5 |
Hi NINfan,
The LM3886 comes in 2 types, the LM3886T and LM3886TF. The LM3886TF is the isolated version which means it can be mounted on the heatsink with only heat transfer compound between the chip and the heatsink. The LM3886T on the other hand needs an isolating material such as a mica washer, to insulate it from the heatsink. neutron7 was implying that maybe one of the chips has a intermittent short to the heatsink, I think??? regards Greg
Greg Erskine |
#6 |
I'm thinking that the heat from that chip isn't going into the heatsink, and the chip goes into thermal shutdown. What we need to know is which version of the chip it is (T or TF), and if you used a mica washer/heat transfer compound between the chip and the heat sink.
#7 |
Thanks for that definition. Well, I checked chipamp.com and the kit I ordered comes with the LM3886TF. I am using heatsink compound, but I have a feeling it may not be making good contact with heatsink.
#8 |
If the heatsink doesn't get too hot, then you are right, the chip is not making good contact with the heatsink. Pull off the chip, clean off the contact areas, make sure that the heatsink contact area is straight, reapply the heat transfer compound, and bolt the chip to the heatsink, making sure it sits flat against the mounting surface.
#9 |
Just redid it, thanks for the adivice. I'll have to crank it tommorow because everyones getting some sleep right now. I'll tell you all how it goes in a few hours, thanks for all your help.
#10 |
Electrons are yellow and more is better!
NINfan, how big is your heatsink? Maybe it's too small? If the heatsink is rather cool but the IC is hot, then you have a problem with the heat transfer between IC and heatsink. If the heatsink is hot, then it is too small.
/Per-Anders (my first name) or P-A as my friends call me |
| Car audio LM3886 + SMPS on single sided board | rwaudio | Chip Amps | 40 | 17th November 2010 12:26 AM |
| What is the current cutting edge in audio? | DJNUBZ | Everything Else | 4 | 28th May 2009 08:55 PM |
| twisted audio pair lm3886 rev. C pcb | Bengali | Chip Amps | 2 | 26th February 2009 03:56 PM |
| Cutting off a piece of an LM3886 (yes, with a saw) | indoubt | Chip Amps | 17 | 12th January 2008 10:27 PM |
| Page generated in 0.09836 seconds (80.51% PHP - 19.49% MySQL) with 10 queries |
