Old 22nd December 2005, 03:58 PM   #1
Default More uf = better sound
I don't really mean that, but adding 16.4Kuf/ch to a "Brian Board LM4780 PS" made a very positive and noticible difference to both the detail and transients. For a reference, the power output capacity jumped from around 89W to 116W with the change. Also, I did add in a little more PS filtering and reduced the grounds from the PS to the amp boards to a single wire. CDs auditioned were "Money for Nothing" (loud) and Rebecca Pigeon's Spanish Harlem on the Ultimate Demo Disc. Everything got better and now sounds discenable better, imaging, resolution, detail..., than my $2800 Yamaha DSP A1 (or whatever it is called). Just though I would throw that out there.
-BG
Old 23rd December 2005, 05:05 PM   #2
What was the capacitance before? I added 15,000uf per rail(up from 220uf,that I used while testing) to my amp and everything balanced out. It also helped stabilized the voltage from the power supply. I did the 1000uf thing first and decided to keep the 15Kuf caps in.
Old 23rd December 2005, 07:57 PM   #3
Cortez is offline Cortez  Hungary
Cortez's Avatar
> ... and reduced the grounds from the PS to the amp boards to a single wire.
What do you mean on reducing ? Shorter GND wires between the PS and the amp ?
Old 24th December 2005, 12:50 PM   #4
The kit comes with 1500 on the rectifier board. I think it is generally a great kit, but requires much more uf, especially for the LM4780 4ohm parallel kit.
The kit comes with 2 ground terminals per ch, so 4 for a 2ch. These terminals are on both the PS boards and also on the amp boards. That means 4 grounds from the 2 PS boards to the amp boards. This having been my first amp, I had a lot to learn. I also thought it important from a learning standpoint to start with the designed kit as a reference. Under these conditions, I had a ground loop between the two channels -- 4 ground wires, about 1 ft, from the 2 PS boards to the 2 amp boards. I tied the 4 together, equidistant, close to the PSs at one point, and the same on the other side near the amp boards. Then one wire between the two "stars"
-BG
Old 24th December 2005, 01:27 PM   #5
Will you post pictures?
Old 24th December 2005, 06:42 PM   #6
zenon is offline zenon  Canada
please do post some type of picture or schematic. There are others "hovering"
Old 25th December 2005, 03:01 AM   #7
Send a message via AIM to safetyman Send a message via MSN to safetyman Send a message via Yahoo to safetyman
I just ordered a set of these LM4780 boards from Peter (Audiosector). Just to confirm, you like it better with the snubber PSU with the 10,000uf and above caps?
Would powering both the dual mono boards of a single transformer with 22-0-22 secondaries work and where would the sero tap be connected to? Is there a gound on the PSU board? I am planning to use this in a bridged cinfiguration. Sorry, noob here, but thanks for any advise given.
Merry Christmas.
Shehzad
Aleph 3 - Diehard fan
Old 25th December 2005, 05:35 AM   #8
safetyman,
From what I've read in these forums using one transformer is fine, you just wire both power supplies in parallel up to it. The thing you have to make sure of is that the total power (VA) the transformer can output will meet the needs of both amplifiers.
Also from what I've read, for those boards you need 300VA for ?each amp?
ie: for a pair of these boards you need 600VA total, correct?
Old 25th December 2005, 03:09 PM   #9
Originally posted by zenon
safetyman,
zenon, thanks for the tip. An EI 600VAC transformer should not be too much of a problem. I can get one custom wound to that, in fact I am thinking of doing a 700 or 800VAC, but the 1500uf caps I mentioned earlier are the ones to upgrade to >10,000uf caps?
Shehzad
Old 25th December 2005, 04:08 PM   #10
Default Agree
I've added 132,000uF per rail (Cheap from apexjr.com) to
my BPA. When I tried this on a single chip it also helps compared
to 1000-2000uF/rail. I'm using a 625 Va transformer.
PC sound card sound chips kaluchka Chip Amps 6 20th June 2011 03:48 PM
SE sound vs Ultra Linear sound flysig Tubes / Valves 1 9th May 2009 10:21 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
Sound, Sound, and more Sound - Instractables Nordic Everything Else 0 5th March 2008 05:43 PM
Roland VS-1 Sound Module - No Sound! jazzbee Instruments and Amps 1 3rd March 2006 08:39 PM
Page generated in 0.10854 seconds (79.50% PHP - 20.50% MySQL) with 10 queries
