hi!!! i've made the REV1 and cant find out what is wrong. I'm getting -V at output.
i measured the +v,-v, GND of LM3886 and +v, -v of lm318 and the values are OK.
anyone else had this problem?
here some pics:
(i know it's ugly, it's just a test).
here some pics:
peranders said:How about the MUTE pin? Connected to anything? No inputs are floating (unconnected)?
MUTE is connected to -V trough a 33K resistor.
mmm i think that there is no input floating, but i will double-check. what is strange to me is that both channels are doing the same think, -V at output.
thanks
Jorge.
BrianDonegan said:My best guesses are:
- A component mounted between the wrong two holes (on both sides)
- A solder bridge jumping tracks (hard to see in pic, but there are several very close tracks on the layout)
- Fried 3886s (less likely I suppose, but possible)
i will check as soon as i can. the first option sounds possible. the first, i checked for jumping tracks, and the third, fried 3886, its possible but they were brand new.
thanks!
I have accidently put components between the wrong holes before. I usually print out the component locations, then draw them in by hand before mounting components now (or use toner transfer and print then right in the board). I kind of like the look of the hand-drawn components though.
BrianDonegan said:I have accidently put components between the wrong holes before. I usually print out the component locations, then draw them in by hand before mounting components now (or use toner transfer and print then right in the board). I kind of like the look of the hand-drawn components though.
great idea, i will start doing it!!! i mean to hand-write the component layout.
Same problem?
http://www.diyaudio.com/forums/showthread.php?postid=795197#post795197
He had full mains voltage on the outputs of both channels, turned out to be a couple reversed caps.
Re: Same problem?
thanks!! i asked him what caps were reversed.
BrianDonegan said:http://www.diyaudio.com/forums/showthread.php?postid=795197#post795197
- Chip Amps
- cant make it work: mauro penasa rev 1
