| Chip Amps Amplifiers based on integrated circuits |
Hi, i am busy building a LM3886 GC. I have a toroidal transformer 17-0-17V/5A. Is this enough for the GC? Speakers are 4 Ohms, 89dB/1W/1m. Thanks, Hans
#2 |
Will give you power supply of something like 2x27 VDC
and trafo is 170VA/5A I say you would have a nice supply for two LM3886 = stereo. I would have only trafo in common for these two channels and each one LM3886 having its own rectifier ( 4 diodes or rectifier bridge) and supply caps. |
#3 |
I think a 17-0-17 transformer should give you about 50 Watts per channel into 4 ohms. This is more than sufficient for 89 dB/W/m speakers. Plus, you don't need to use a big heatsink...Actually, I built a subwofer amp using 17-0-17 with about 160 VA and my sub isn't terribly efficient!
#4 |
170VA::good.will suffice for stereo also.
but 17v ac gives approx 23v dc.very low to exploit fully the potential of 3886.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum |
#5 |
The National Datasheet says that at 23v the 3886 will output around 40 watts into 6
ohms, a little less for 8ohms. That should be enough to drive most speakers. Google LM3886. The first link is Nationals site for the 3886. Download the datasheet. Go to Typical Performance Charts. There's a graph on page 14 called "Output Power vs. Supply Voltage" that will tell you how much power you need to achieve how many watts. -Aaron. |
| lm 3886 | larryg | Chip Amps | 6 | 1st June 2009 06:38 PM |
| Using +/-70V on a LM 3886 | Pery | Chip Amps | 17 | 23rd July 2007 09:58 PM |
| pre amp for 3886 | bostonswoop | Chip Amps | 6 | 19th June 2006 02:58 PM |
| Is this a good transformer for LM 3886? | maurycy | Chip Amps | 6 | 15th January 2006 03:03 AM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 06:51 AM |
| Page generated in 0.08141 seconds (65.75% PHP - 34.25% MySQL) with 10 queries |
