| Chip Amps Amplifiers based on integrated circuits |
If I parallel two amplifiers into some speakers, leave them both switched on, and then switch the input signal from A to B, does the amp without a signal effect the output from the 'active' amp ?
Does the answer depend on whether the amps are nominally the same? or whether they have output resistors? |
#2 |
i wouldnt do that! it could possibly lead to release of smoke. and definately change and distort the sound by quite a lot.
imagine one amp is trying to stay at 0v because it has no input. while the other one is trying to play music. though a speaker, and throughj another amplifiers output stage. what happens when the non playing amplifiers feedback circuit sees the signal there it will try and swing the output to compensate. then the playing amplifier will have to do something to compensate for that. and make it even worse. maybe a high power oscillation that blows amplifiers and even the speaker. switch the output as well as the input for a proper a/b comparison. if you decide not to switch the input you may or may not have impedance matching problems, which could affect the sound but you wont blow anything up. |
#3 |
I wouldnt do that either, the one active amp will dump current to the inactive amp, poof smoke good by chip
| Another first chipamp | A Sanchez | Chip Amps | 18 | 4th June 2008 07:44 AM |
| Chipamp with SMP | pjpoes | Chip Amps | 10 | 23rd June 2007 11:20 AM |
| chipamp ccs | elmar | Pass Labs | 0 | 14th December 2006 04:04 PM |
| chipamp.com | renfrow | Chip Amps | 14 | 11th August 2006 08:10 AM |
| FS chipamp and dac | eapavant | Swap Meet | 16 | 3rd August 2006 05:10 PM |
| Page generated in 0.06200 seconds (80.09% PHP - 19.91% MySQL) with 10 queries |
