values?
C6- 1uf
R3-1K
R5-22K
eliminate C8
R4-22.1K
R1-1K
C7- 22uf to 47uf polarized, tantalum, or NP 4.7uf to 22uf ect....
C3&C4 100uf to 1500uf your taste
C1&C2 100nf
Li- 7.4mh
R1- 10 ohm 2 watt
R2-2.7 ohm
C5-1uf
eliminate all component on mute pin. Use a 10k and a 100uf polarized cap - to ground.
C6- 1uf
R3-1K
R5-22K
eliminate C8
R4-22.1K
R1-1K
C1&C2 100nf
Li- 7.4mh
R1- 10 ohm 2 watt
R2-2.7 ohm
C5-1uf
mute pin
First I made a mistake, L1 should be .7mh dont know what I was thinking when I typed 7.4???? Just wind 10 turns of .4 enamel wire on the body of the 10 ohn 2watt resistor.
The mute pin needs 20ma at V- to shut off the mute feature. When the pin is open mute is active.
- Chip Amps
- help with design
