| Chip Amps Amplifiers based on integrated circuits |
I have boards from the BrianGT Mini-Aleph group buy, and I also have a BrianGT kit for a LM4780 gainclone. I am interested in building both amplifiers, and I'm wondering if I can use the Aleph power supply for both amplifiers. I was thinking of building the 34 volt version in an external case (maybe even two cases for complete dual mono power supplies, I have two power supply boards) and am wondering if the two amplifiers could utilize the same supply. This would save me time and effort, and I could concentrate expense and effort into building one really good supply that I could use with both amps instead of building two completely different power supplies.
I am very open to suggestions as I am relative newbie. Thank you for your time and help. -Aaron. |
#2 |
34 Volts sounds awfully high for a mini A, is this for 16 ohm speakers, or am I missing something here?
Be sure your foil hat has a good low impedance ground. |
#3 |
I am feeding my GC 33.5VDC, it is an LM3875 though, and I don't drive 4 ohm speakers either...
#4 |
As far as the 34 volt supply goes, I guess mini-aleph is a bit of a misnomer. The boards from the group buy can be used to make a number of different iterations of the Aleph, and I have enough to make an Aleph 60, which would need the 34 volt supply. (correct me if I'm wrong)
My question wasn't really about whether or not it would provide enough voltage, but about whether or not the other specs of the supply would mate well with the gainclone. I guess the only way to know is to try. I'm held up a bit by figuring out where I can source parts for a chassis (I'd like to build something like the Patek amp by peter daniels), and building the power supplies. Ambition and interest exceed knowledge and talent as far as building goes. Would be nice for me if everything came in one kit and I could just follow instructions and build. Thanks for taking the time to respond to my query. -Aaron. |
| gainclone power supply | student | Chip Amps | 49 | 21st July 2010 09:38 PM |
| Gainclone Power Supply | iandrum | Power Supplies | 11 | 28th January 2009 02:23 PM |
| mini aleph VS gainclone VS Class D amp | ecl86 | Pass Labs | 3 | 23rd June 2007 05:20 PM |
| Mini A Power Supply | harry303 | Pass Labs | 4 | 31st December 2004 01:41 PM |
| Gainclone power supply | soundNERD | Chip Amps | 10 | 4th February 2004 01:31 AM |
| Page generated in 0.08162 seconds (68.05% PHP - 31.95% MySQL) with 10 queries |
