| Chip Amps Amplifiers based on integrated circuits |
I want to build a pre-amp box that will contain passive attenuator, a simple buffer and an active crossover. It will also let me switch sources between CD and AVamp, thus letting me remove the AV amp for music.
Opinion seems to be that stepped attenuator beats potentiometer, so does anyone know where I can get a kit of parts? Or can recommend where to buy the dual 12way switch (does it need to be a quality item?). Maybe someone has a built attenuator for sale? |
#2 |
#3 |
diyAudio Moderator Emeritus
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#4 |
thanks for those replies. I'm getting a shipping price for the built one. I have read most of decibel dungeon, but I hadn't spotted the pre-amp/crossover, exactly what I want.
#5 |
Quality is a relative term.
I built my passive pre using Shallco switches (coin silver contacts, high wipe, high pressure) bought at Michael Percy. He also carries several brands of audiophile resistors priced from oh dear to oh my god. 12 steps seems minimal, if I were to do mine again I would choose steps of 1.5 dB in the nominal listening volume range. Outside that range I would expand to 3 dB steps and then maybe 6 or 10 dB. A good design would probably run from -40 to +6 dB total range. So 3 steps of 6dB gets you from -40 to -28, then maybe 4 steps of 3dB gets you to -16. Now 7 steps of 1.5dB each gets you to -6.5 followed by 4 steps of 3 dB to get to +5.5. That's 18 steps, a lot of resistors. My passive stacks up against the very best pre-amp sound quality I have ever heard. For all the work you are about to do, I would consider buying very good parts in order to make it the last one you'll ever build. |
#6 |
Thanks for the comments, I think I'll start with a mid-range unit though as I've only just added pre-amp to my list of things to build and I'm not ready for $300 attenuators yet.
Besides, if I started with a $300 shalco I wouldn't have anything to reference it against. |
#7 |
The Shallco is only $94 it's the damn vishay resistors that run $300.
#8 |
#9 |
Look out for Winkler stud switches. Expensive new, but available as military surplus sometimes. They come with silver- or gold-plated contacts, and are excellent in this application.
#10 |
White Noise Audio UK based and a nice guy to deal with.
| diy stepped attenuator under 10$ | kaushik | Parts | 23 | 12th January 2012 10:37 AM |
| stepped attenuator | onno | Pass Labs | 20 | 25th September 2007 09:04 PM |
| Stepped attenuator | Bas Horneman | Tubes / Valves | 24 | 16th June 2004 07:18 AM |
| Stepped Attenuator | officeboy | Parts | 3 | 6th May 2004 03:32 PM |
| Page generated in 0.10125 seconds (78.04% PHP - 21.96% MySQL) with 10 queries |
