| Chip Amps Amplifiers based on integrated circuits |
Hi
In a frantic bid to eliminate all caps in the signal path (don't ask, the quality of all caps in India is way below average, I get horrible results with any kind of cap and good sonics with no caps), I have removed the output coupling caps on my CD Player as well as the input cap on my P2P-wired LM 4766 chipamp (currently with its legs in the air mounted on a heatsink and no other case). I get about 20 mV offset in worst case (volume pot turned to zero) and about 1mV at best (fully open pot) and the offset varies with the travel of the wiper on the pot (due to the input impedance varying). Before removing the caps my offset was about 1 mV-2mV on both channels. Input offset (from CD-player) is about 3 mV. I guess in theory I'm flirting with disaster. In practice, has anyone done this and what are the dangers of doing so? Currently I'm running a set of cheap woofers, so I'm not going to cry if they blow but I'm looking at a speaker upgrade real soon and I don't want to do one more immediately afterwards. |
#2 | |
plz don say so in this forum.what image u r projecting of your own country?think,,,,,,,plz the main prob lies in p2p(believe me),my first amp was p2p and horrible,transferred to pcb....still up and running great. CAPS,use philips(only those can b gurranteed genuine bec,,purchase only from philips shop[there is only one official philips shop in lajpat rai market here in Delhi,i purchase all the req. yes all the req. from there only.]).they sell in bulk(for 100nf etc,500pcs min@50p),i don mind payin when i know thing is good and genuine. u can make pcb very easily using the toner xfer process.(discovered recently,, 4 me ).Sangram,rest assured,pcb will solve prob(noise,sonics etc) regarding caps.:::::: i removed power decoupling caps from tda8563 amp,even removed the signal caps!yes,its true.the amp sound improved greatly.maybe ,the caps were degrading sound.issue can be::1)quality,bec they were local,Rs 2 for4700uf/25v!:::2)polarity could b wrong,wrongly inserted by me....... it was a bore amp(to make),so i never bothered bout all that.but,one fine day i started the amp,and it didnt work.what could b the reason.its still dead.maybe lack of capacitors ate it away.(most likely,bec rest all modules like xformer,rectifier etc working else where sucessfully).there was no spark,noise sound etc,jus silence,amp dead!
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum |
#3 |
Yes, you ARE flirting with disaster.
You may be upgrading your speakers sooner than you think. Is speaker quality in India higher than capacitor quality? I_F |
#4 | |
my country got all,but in bulk only.u have to search and research hard to get good things loose. its like sifting thru ATM for change.
#5 |
#6 |
hi nordic,
that was bec of shorting(the bench i was working on had wires strewn all over).i dunno what shorted what,but i lost the setup.
#7 | ||||
Seriously, it is true, you say later down the post that DIY is nascent. Availability of good components is very very poor.Quote:
You're joking about P2P, right? The only time a PCB is better is when you can't actually solder correctly in P2P and wires fly fast and thick, come loose etc. The sound quality beats many commercial amps. But without the cap. Quote:
They're just OK for supply decoupling and filtering, but for series audio, even the cheap chinese greencaps have lower ESR and sound better. Quote:
![]() I think no more need be said, I'll order a few BG-Ns from Digikey. |
#8 | ||||
hi Sangram,
u r a seasoned diy'er.i m new in this field(serious diy).but my experience to get components is OK OK(good not possible here,bec hard work req.). it seems from your posts that u have had very bad experience. Quote:
.searching is needed to get the sources who will give u good components in small quantities.easily available components r .good ones r available,but in bulk,now its upto u how u get them in quantiies u req.after about 2 yrs,its a breeze to get what i need(almost 90% r got).currently i m looking for opa134 series.if i fail to get it in Delhi,i'll get it from b'lore. Quote:
#9 |
No not a very bad experience - until the point I had a system good enough to reveal the difference.
You can get a good idea of the quality of the cap and some of its basic specs. All parameters have an effect, and ESR (or at least what I understand as ESR) is not very different. Since I've been doing lots of tests in the last few weeks, I automatically correlate the sonic signature to ESR. Technically it may not be correct, but basically I sense a HF rolloff which is easily corrected by paralleling a film cap. AFAIK Philips does not make passives any more, so I think what you're getting is all NOS. Which is not necessarily a bad thing. BC is now part of Vishay, I don't know if they still have a license for India where they use the Philips name for marketing - I doubt it. Getting good actives is never the problem. Good passives, transformers, cases etc are the issue. But specially passives. Anyway let's not sidetrack this discussion. There's a lot of India-specific threads with regard to components. Referring to those will be better, or posting there on this aspect. As far as input caps go, I'll look at getting some quality caps from Digikey or RS India. To update results, at about half travel the offset is at a very respectable 2 mV on one channel and 1 mV on the other, and I do take care to switch on the amp after the player and switch off before, so that speakers are protected from transients, but I do believe that under some conditions there may be a DC surge in the CDP output, so I'll take some hit on SQ to put in caps. I need about 100 uF for a lower F cutoff of 1.6 Hz (1 Kohm load - inverting amp) which will be roughly where I want the cutoff to be. Which means exotic films are out. The lowest possible is 22 uF, for about 7.2 Hz, but we'll still get some audible band problems... The other option is to use 10000 uF on the outputs and parallel the hell out of them (1000, 100, 10 and 1 and .1 uF) to get acceptable performance, but that is a distant second choice. |
#10 |
I'm running my bridged LM4780 without any coupling cap.
I get 3mV offset when the pot is down, and 9mV when at maximum. I use a laptop as soundcard right now. Don't think it has any coupling cap, I opened it once and didn't see any. Never tried to use a cap, but sound is so transparent without it that I don't wanna try !
| Ci and DC offset ?? | decky | Chip Amps | 29 | 15th February 2008 10:35 PM |
| Max variance between SMPS rails? | thefish | Power Supplies | 6 | 12th December 2006 12:23 PM |
| Help With DC Offset | Sybex23 | Chip Amps | 8 | 15th November 2004 07:11 PM |
| 4v dc offset | xplod1236 | Chip Amps | 2 | 23rd April 2004 06:24 AM |
| 10V DC offset | JoeBob | Chip Amps | 8 | 6th August 2003 11:13 AM |
| Page generated in 0.14828 seconds (76.13% PHP - 23.87% MySQL) with 10 queries |
