How to wire 2 center tapped transformers
Old 8th December 2005, 12:53 AM   #1
angsuman is offline angsuman  United States
Default How to wire 2 center tapped transformers
Hi everyone,
I'm interested in getting the LM3875 briangt gainclone kit.
The project is budget motivated, and as a learning block for electronics.
However, all the dual secondaries toroidal transformers are too expensive for me. I'm curious that if i take 2 radioshack 25.2V CT 2.0A
transformers or 2 12.6V CT 3.0A transformers, if i can get away with that instead of dual secondaries. Also, how would i wire these transformers.
Old 8th December 2005, 01:18 AM   #2
woody is offline woody
You might check out www.apexjr.com he has a lot of surplus
transformers and caps at real good prices. Oh! shure you can
use 2 transformers but if this is one of your first projects I would
subjest just using a center tapped one less things to go wrong.
How to wire 2 center tapped transformersHide this!Advertise here!
Center tapped transformer help Buzzy Parts 2 8th August 2008 10:35 AM
WTB 2:1 center tapped trafo in the UK MikeHunt79 Swap Meet 0 15th January 2008 02:46 AM
Wiring Toroid 14V non center tapped for PSU civilmonkey Chip Amps 7 23rd September 2006 09:12 PM
Two Transfomers => Center Tapped? Myren Analogue Source 6 12th April 2004 03:22 AM
Center tapped choke loading Bandersnatch Tubes / Valves 10 8th July 2003 12:56 PM
