Old 7th December 2005, 05:00 PM   #1
Default Decent LM3886 amplifier
hello guys.
i'd wanted to build 3886 amplifier for a long time, but couldn't decide wich schematic to use. i found this forum several days ago(it was such a surprise for me that lm3886's were such respected chipamps), and downloaded several schematics from here.
my problem is that i can only build schematic, and i'm totaly helpless in creativity. i mean looking/examining scheme i can not figure out what and how to change to make it work and sound better.
well, i'm looking for help and advice from you guys.
which schematic do you recomend to build, looking at quality - not simplicity? i know, "best" is word subjective, and if it cannot be said wich design is best, it certainly can be said wich ones not to build. so there must be well proven designs, that are a head above over others.
i understand that this question would be often raised up, and that i should use search, but searching this forum and finding long threads(some over 170 pages ) they say nothing to me because higher skills required to understand them.
well, i have built several amps before, solid state and tube, so i'm not totally dumb at all
my goal is to build decent sounding (as much can be achaived from 3886's) amplifier for 60 wats of power at 4 ohms of load.
can someone give some decent schematics?
thanks for reading this
Old 7th December 2005, 06:25 PM   #2
Well Georgiano
you an always start with this one
http://www.diyaudio.com/forums/showt...507#post609507
it is very good and sounds really nice. but if you want to really make it compelling you can try this for size. it is the same amp with a beefed up power supply, and there is just no touching it
http://www.diyaudio.com/forums/showt...679#post782679
then there is always the design from Carlos. I never heard it but he swears by it. much less complex
http://www.diyaudio.com/forums/showt...271#post783271
but i have to admit that the X-Calibre is my favourite. (but i would say say, since i have done all the work on it)
Old 7th December 2005, 10:22 PM   #3
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I would recommend you use circuit that is in Lm3886 datasheet.
It can be found at www.national.com
It is very simple and easy to build.
However , don't forget that all ground connections must come to a one ground point.Forgetting to do so may cause stability problems or/and increased distortion.
Old 8th December 2005, 05:08 AM   #4
Jay is offline Jay  Indonesia
The balanced one is the best sounding. But it is not a well proven design. Unless you know electronics well, you should find help from metalman to build one without much problem. Unless Nelson Pass himself design the schematic, I will prefer to stay away
Old 8th December 2005, 03:05 PM   #5
sagarverma's Avatar
hi Jay,
its your territory(lm).advise req.i also need that(my lm amp burned out and took away my $100 pioneer woofer with it )
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 8th December 2005, 07:27 PM   #6
Default qqq
Well Georgiano
http://www.diyaudio.com/forums/show...9507#post609507
http://www.diyaudio.com/forums/show...2679#post782679
well, i was considering to build mauros design. i found schematic on first page. but found on 170-th page that there was RevC version of it. i cannot read all the 170 pages. do you have this version of his amp?
i read X-Calibre topic too. is your amp's final version available on topic's first page?
there was also word Thorsen floating around. i couldnt find out what it is, looks like it is a good design too.
something makes me to think that schematic in datasheet shouldn't be the greatest available. i don't like "example" word in there
sounds chinese to my ears
Old 9th December 2005, 06:05 AM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
Somewhere between page 152 and 156, we posted the full schematic.... sure you'll find it now.
Old 12th December 2005, 10:34 AM   #8
Hi sagarverma,
nice cat you have there! I always like cats because they seems to like me. I don't know why, but I guess they have a good intuition about good people
Anyway, I have lots of experience with chip amps in the past, but not with GC. I built several GC but don't have enough time for tweaking and comparing with the same setup, so it is actually difficult to tell which schematic is better than which.
Often, first impression tells the truth. So I was impressed with balanced one (hi georgiano, sound chinese you said?), and the single supply example. (Hi georgiano, National examples are not as bad as Philips').
And then about inverting schematic. It is almost coincidence that everytime I like my chip amps (or opamps pre), they happen to be inverted. And I have good impression with inverted GC as well (compared to non-inverted).
Old 12th December 2005, 02:13 PM   #9
sagarverma's Avatar
hi jay,
i have made only single ckt of lm,from app. notes.its ok.but due to my fault,it smoked out and took my woofer with it.
offline::::::cats r cute,so r cubs(lion's strictly).
Old 12th December 2005, 03:26 PM   #10
yep
yea, but i am looking for the good one, not for "not as bad" one.
LM3886 as transconductance amplifier? squadra Chip Amps 4 23rd April 2008 10:16 PM
Wanted: Alesis amplifier modules, decent op-amps, and Seas W17EX001 drivers Spasticteapot Swap Meet 1 1st March 2007 06:13 PM
LM3886 Amplifier help Jack Bruce Chip Amps 3 16th January 2007 12:25 AM
LM3886 amplifier problem mbates14 Chip Amps 9 11th August 2004 08:42 PM
LM3886 amplifier soundNERD Chip Amps 20 28th September 2003 12:20 PM
Page generated in 0.12240 seconds (79.65% PHP - 20.35% MySQL) with 10 queries
