| Chip Amps Amplifiers based on integrated circuits |
Hello!
First, sorry bad english... I have BrianGT Gainclone premium kit, and that work very good! Sound is beatyful. I use 18V/200 transform...how i doing "power led" circuit? I try couple time, but 4-7 day and led broken... I use 10kohm resistor only... Please help me, and draw circuit, when i dont cant doing wrong... |
#2 |
Did it Himself
Connect LED across +ve and -ve DC rails and use 1k ohm 3 watt resistor. This way will make LED fade as rails discharge.
Or connect a diode in opposite way to LED but across it, use 680 ohm 2 watt resistor, and connect across AC winding. This way will make LED go out as soon as power switched off.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
I connected one this weekend for the first time, just soldered a 1.5k resistor to the one leg on the LED, and then soldered the positive side to the positive pole on a cap in the PSU, and the negative one to the 0V point.
1K is enough for the voltage your trannie does... if its a dual rail supply, if I understand, then there will be 2 x 18V between Ve+ and -, thats why I say connect beteen ground rail and either of the supply rails... with single supply this is not a problem I would venture... not that familiar with brian's circuit anymore |
#4 |
Did it Himself
You can connect between one rail and ground, this would lower the wattage required for your resistor (but it's resistance would need reducing), but this injects the LED current into your ground. Not a big issue, but seeing as how most people are claiming massive things with component changes on one then it seems stupid to do something that would be grossly more worse than changing a resistor brand
#5 |
I see, yes I calculated it based on my 33.5V supply lines, I'll take your tip to heart and see if I can get bigger value/higher wattaeg resistors, just a shame they wont fit into the LED holder.
#6 |
you can allways do it like i did...
take some wire and wind it on the transformer 2-3 times.. its the simpliest way (at least for me)
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.08446 seconds (74.03% PHP - 25.97% MySQL) with 10 queries |
