| Chip Amps Amplifiers based on integrated circuits |
Hi all,
Here are pictures of my very first finished amp. It works really great. There is just one thing I don't understand: when I turn it off, few seconds after that it seems to turn on for a short while. Do anyboy knows why is this? Thank you all for your help. Martin |
#2 |
and another one...
#3 |
Wow, thats a nice neat compact implementation. I am not sure I can diagnose your turn off problem, but I will mull it over.
![]() Good job, I bet it sounds great.
Less pulp more juice Twisted Pear Audio. |
#4 | |
Take |
#5 |
Hi Take,
Yes, this is exactly what my amp is doing... Did you managed to fix it? Or I don't have to worry about it? Thanks Martin |
#6 |
No, haven't fixed it (I'm still in the proces of building the other channel), but I'm not too worried either. I'll be watching this thread to see if anyone has a solution (or just an explanation).
Take |
#7 |
No solution here, but just to let you know mine does the same thing and is running fine.
Maybe it has something to do with the chip shutting off after the inevitable voltage drop following a few seconds of playing music without power (the length depending on how much uF you have in your PSU), which could somehow recover in the electrolytic caps to give one more (very) short burst of music? |
#8 | |
Banned
#9 |
Carlos,
That could very well be the solution although to a problem that I personally do not perceive as a one. Once you decide to stop listening, why not shut down all your equipment? Or is there someone out there who insists that repeatedly powering up/down a GC is bad for music reproduction :-) |
#10 |
Without the bleeders, if you switch the amp off regularly the capacitors stays in this neither fully charged or discharged state which is not good for them...
| LM3875 Kit Finished - Could use some more bass | johan851 | Chip Amps | 91 | 31st March 2008 01:13 PM |
| Audiosector/Chipamp LM3875 or Mauro Penasa's My Reference RevC from Twisted Pear | blottojon | Chip Amps | 14 | 8th March 2006 09:48 AM |
| LM3875-semi finished | enzedone | Chip Amps | 17 | 16th February 2006 04:19 AM |
| Page generated in 0.09440 seconds (84.30% PHP - 15.70% MySQL) with 11 queries |
