X-Calibre : Hot Rodding Mauro Penasa's LM3886 design - Page 4 - diyAudio
Old 6th December 2005, 07:16 PM   #31
t. is offline t.  United Kingdom
t.'s Avatar
Originally posted by rudi
t. download them and rename them with a .zip at the end then it works fine
Carlos you hijacker - just kidding
Cheers Rudi!
I'll give it a try
Old 6th December 2005, 07:23 PM   #32
Originally posted by t.
I admit to liking the MUR860's probably best with the GC amps though and the Schottkies better if regulators are used
T , just somehting that i have noticed. with the X the MBR 10100 were better, and with a snubber evenmore so. but you will let us know when you build yours. it was a compromise because i need to do the entrire spectrum with the amp and for that reason i chose the MUR860
NB: anybody that wants to build the amp with MBR10100 should be aware that you would not have all the bass you are used to. and if you have a small speaker system then the MBR are not recommended. but with a proper fullrange system you will be richly rewarded
Old 6th December 2005, 07:40 PM   #33
t.'s Avatar
Thats better, nice one Rudi
I'll let you know as soon as I can get the new board built, this is going to be a busy month for me
It goes quite for a while and all these projects come at once
Sorry to go off topic
Thats an interesting looking pre-amp Carlos
I've actually got a couple of those SMD AD815's but never used them for anything yet, I can easily modify your amp and implement the AD815 if I can find my magnifying glass and tweezers
Is there any threads with the layout? I could build this easy enough from your schematic but how did you manage to fit all the parts so close to the chip, its tiny
I could cheat and etch a board but no doubt its not as good as a tightly done p2p
Old 6th December 2005, 09:46 PM   #34
Banned
Did you have any problem downloading the file?
It's a .zip, with 3 .png graphic files inside...
That may as well be the preamp of your life.
I'm not joking, this is serious.
And you can use it with whatever amp you have.
Leo, the chip is not tiny, even the SMD version is quite big and relatively easy to work with.
Look at the datasheet for the pinout of the SMD version.
It has a perfect pinout.
It has the PSU pins located exactly where all the op-amps should, I mean if it was an 8 leg thing that would be pins 4 and 5.
I have never made a PCB for it, although I had the intention (but no time). My prototype (on veroboard) ended up as definitive inside my pre.
Some weeks ago Peter Daniel sent me some non-smd AD815 chips and I made this test setup.
Old 6th December 2005, 09:47 PM   #35
Banned
This heatsink is very oversized. It doesn't even get warm.
Old 6th December 2005, 10:00 PM   #36
t.'s Avatar
Hi Carlos,
I could download your file but the pc would not open it, as soon as I added .zip at the end of the file name suggested by Rudi it worked fine
I've just dug out my smd AD815, your right, its not as small as I thought but I know how important the layout is so i'd like to get it right
Excellent work from you again and thanks for sharing I'll have a dig through my parts box, I've been after a nice pre for a while, I've got Nuuks tube pre to try too.
I presume an 8v reg would be ok for the nulling circuit
Old 6th December 2005, 10:33 PM   #37
Banned
Yes, it's fine.
Old 7th December 2005, 04:39 AM   #38
carlosfm,
i remember you posted the source of your 10k pots...(the green sturdy looking ones in your non soic 815 preamp)
could you post the link again?
i can't seem to find a good 10k pot other than the panasonic ones... (in the US)
thanks,
Old 7th December 2005, 04:47 AM   #39
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The small pot was described here: "Silver-Carbon" Pot ex Tawan - Photo - & ignore my ugly Pinky!
In US, percyaudio.com caries good selection of pots, the $20 Nobles being pretty good choice.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th December 2005, 05:07 AM   #40
jaycar double gang log pot
well the green pot is only 5 dollars... (which is better than 20 dollars... at this point in my life)
i will post my 815 preamp implementation shortly.
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 05:28 PM
My Version of Mauro Penasa's LM3886 Stanley Drake Chip Amps 28 31st December 2006 12:41 AM
Mauro Penasa's INV GC/REF GC group buy. Russ White Group Buys 277 27th March 2006 08:57 AM
Copyright ©1999-2017 diyAudio
