Old 26th September 2007, 08:45 PM   #151
Not to jump in on top of Salesmonster but ...
Those files with the '.GBR' extension are Gerber files as required by PC board houses for production.
The '.LAY' file is the project file as created by the 'Sprint-Layout' PCB editor. It happens to be my board editor of choice!
http://www.abacom-online.de/uk/html/sprint-layout.html
Carl
Old 26th September 2007, 09:51 PM   #152
salesmonster's Avatar
The .lay files are Sprint files. You can find a viewer here: http://abacom-online.de/uk/html/date...ewlayout50.exe
The .gbr files are Gerber files that are used by a lot of PC Board manufacturers to do the copper and silkscreen layers on a board.
The .drl file works with the Gerber file. It is a drill hole file. It indicates the size and location of each hole.
If there is any interest, I have tweeked the 1 Layer and 2 Layer boards to make for easier manufacturing. I used the DRM checker @ batchpcb.com to verify manufacturability (The one at 4pcb.com was driving me NUTS).
The size (100mm x 160mm) was chosen because it is a standard panel size at olimex.com. It looks like they can build the 1 Layer version for $26 and the 2 Layer version for $33. The only functional difference between the 2 versions is the use of wire links and zero ohm resistors.
With Olimex it looks like shipping to the US would be $9 for slow boat shipping.
BatchPCB.com looks like they may actually be a better choice if you are looking for a contact based in the US. They contract out to Asia for the manufacturing, while they are the re-seller.
Has anyone used either of these 2 companies?
Old 26th September 2007, 10:03 PM   #153
you can have a much better deal with www.pcbcart.com
can you send me your file please. will like to see it.
I have since stopped listening to this amp but i must admit it is still a very good amp
Old 26th September 2007, 10:44 PM   #154
Rudi: Thanks for the tip.
Also, check your email.
Dave
Old 27th September 2007, 12:28 AM   #155
Where can I get those .lay files?
Those named as 1 and 2 are not lay types.
Old 27th September 2007, 03:51 AM   #156
Here you go.
Old 27th September 2007, 01:33 PM   #157
I can't seem to open the file.
Winzip doesn't recognize it, neither does Sprint-Layout. Not even renaming the file as lay can I open it.
Can't you post a lay file?
Old 27th September 2007, 03:07 PM   #158
The only valid extension for upload are: gif jpg png txt zip jpeg pdf.
I've noticed with some files here at diyaudio.com, sometimes the extension is stripped away when you download them. Remane th file and add the .zip extension. Then you should be able to open it.
Does anyone know why the site does that, and how to fix it?
Dave
Old 27th September 2007, 03:46 PM   #159
ppcblaster's Avatar
Default If tyou can't see the .zip
or other suffix, go to folder, view, and see if you have file extensions checked.
I downloaded the lay file and it unzipped.
try winrar it unzips anything.
Old 27th September 2007, 04:03 PM   #160
PPCBlaster: What part of Ohio are you in?
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 05:28 PM
My Version of Mauro Penasa's LM3886 Stanley Drake Chip Amps 28 31st December 2006 12:41 AM
Mauro Penasa's INV GC/REF GC group buy. Russ White Group Buys 277 27th March 2006 08:57 AM
Copyright ©1999-2013 diyAudio
