X-Calibre : Hot Rodding Mauro Penasa's LM3886 design X-Calibre : Hot Rodding Mauro Penasa's LM3886 design - Page 13 - diyAudio
Old 14th December 2005, 07:21 PM   #121
rudi is offline rudi
Thank you kind SIR
Old 15th December 2005, 03:28 AM   #122
Nordic is offline Nordic  South Africa
Nordic's Avatar
Oi, not yet boertjie....
How far is my boards, wink wink, nudge nudge...
Old 15th December 2005, 03:17 PM   #123
zafira1981 is offline zafira1981  Argentina
Hi!!!!
I'm planning to build this amp but i dont know what kind of caps/voltage I should use for each one. I dont have enough knowledge to decide myself.
can anyone help me ?
THANKS!!!!
Jorge.
Old 15th December 2005, 03:46 PM   #124
safetyman is offline safetyman  Malaysia
Send a message via AIM to safetyman Send a message via MSN to safetyman Send a message via Yahoo to safetyman
rudi, are you planning a group buy for the boards of this amp or offering it like Brian and Russ is doing at TP? I am interested to get a set of the final boards and PSU boards too.
Shehzad
Aleph 3 - Diehard fan
Old 15th December 2005, 08:49 PM   #125
Hi Jorge, i got your mail but i have the message still in my drafts box.
for the main caps 10 000 and the 220uf you can use anything above 40V 50 v would be better
the caps 100uf on the supply for th eLM318 you can use 25v and 35-50v for the speaker protection. the 470uf you can use anything above 25v but above 35v would be better
then regarding the group buy
I do not have permission form Mauro yet to make this commercial. but even if i do , i will only do it in the new year. I might even commission somebody to do this seeing that I do not have the time to really persue this to much
If there is anybody out there interrested in creating a group buy please contact me. I will speak to Mauro. but first and formost we have to respect his wishes
Old 15th December 2005, 11:04 PM   #126
Thanks!!!!!!
Jorge
Old 17th December 2005, 07:31 AM   #127
Default Final PCB
Ok I have been doing some work on this and made some changes. I can't see myself changing more than this,
you still have the option of regulators or just Zeners. i dumped the idea of having both
you have a semi-split ground plane for the Lm3886
and you also have various cap options for the Lm3886 supply and then you can also put a RC filter on the LM318 supply. all caps have been moved closer to the pins and tracks are as short as possible
there is now two LED on the board, speaker on and speaker off
PDF is A4 and the board should measure 175mm x 150mm
Enjoy
Old 17th December 2005, 07:33 AM   #128
Default Copper
Here is the Copper view from the component side
board measures 175 mm x 150 mm
print out on A4
Old 17th December 2005, 07:35 AM   #129
Default Silkscreen
silkscreen
Old 17th December 2005, 07:38 AM   #130
Default Alternative components
I have allowed for variations as mentioned.
here you can see the zener layout
RC filter caps
various caps sizes for Lm3886
Ref A conversion - you remove all components that says C next to the values
and the 3k3 bias resistor
X-Calibre : Hot Rodding Mauro Penasa's LM3886 designHide this!Advertise here!
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 05:28 PM
My Version of Mauro Penasa's LM3886 Stanley Drake Chip Amps 28 31st December 2006 12:41 AM
Mauro Penasa's INV GC/REF GC group buy. Russ White Group Buys 277 27th March 2006 08:57 AM
Copyright ©1999-2017 diyAudio
