nice
VERY nice!!!
I especially like the way you geared the volume pots.
Keep up the nice work.
What'r ya building next?
VERY nice!!!
The case was made out of .125 6061 plate screwed together with flat head cap screws. The front is made out of .375 6061
with an acrylic ring pressed into a hole that was bored in the
face. It is lit by electroluminescent wire behind the ring. The knob is flush with the face and supported by two bearings.
The gear set up is made from RC car gears I hade laying around.
The amp is BrainGT's LM3886 kit
Here is a pic of the gear set up
Nice Gears.
For a first project, that is mighty fine work, congrats! Very impressive consruction and metal work.
Nice gears, how are they working out?
Here are my preamp gears. Other than needing a lot of force on the handle you are turning, and you needing to be careful about how far you turn them (and the direction), they work great.
Wow that is beautiful
Nice job!
It's great to see the power supply in its own "box", essentially.
Would you be willing to say more about the details? The transformer looks potted...very nice. Where did you get it? What voltage did you go with? What kind of posts and rca-s are those? Etc.
Again, congratulations!
Nice job!
- Chip Amps
- Finished First DIY Project
