Old 4th December 2005, 08:24 AM   #1
Default Star Ground technique
I have done a search both in the forum and web for star ground method. The information given are bit confusing and contradictory. Can some guru in the forum give a clear account on the correct method with a block diagram?
In my main system the signal ground is a separate ground isolated by 10R. Where shall I connect the signal ground? Where and when does one need to put Zobel isolators in ground connection.
Old 4th December 2005, 08:32 AM   #2
Wynand is offline Wynand  South Africa
Wynand's Avatar
just look at the thread called "multiple grounds" its still a recent thread and you should still see it on the main chip amps page
Old 4th December 2005, 11:41 AM   #3
Mick_F is offline Mick_F  Germany
Have a look at this page (scroll down a bit), where I show a schematic of the grounding scheme I used for a chipamp with separate PSU. It is absolutely silent.
Mick
No statement here.
star ground vs. ground plane Sebastiaan Chip Amps 15 10th May 2009 05:05 PM
Star ground help g(f(e)) Tubes / Valves 26 24th December 2007 10:08 PM
Will this amp need a star ground? ghetto Chip Amps 3 25th August 2007 05:25 PM
Ground planes instead of star ground svokke Chip Amps 3 22nd October 2003 01:01 AM
Star ground naula Solid State 13 16th October 2003 07:43 PM
Page generated in 0.07942 seconds (61.55% PHP - 38.45% MySQL) with 10 queries
