Transformer wiring problem - Page 2 - diyAudio
Old 2nd December 2005, 07:26 PM   #11
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
mrlots2do,
ok, so why do you recommend your approach over this 4 diode setup??
Thanks Martin
Old 2nd December 2005, 07:42 PM   #12
mrlots2do's Avatar
I'm not saying it is my approach. How can wiring a ct trans as I mentioned cause smoke? I don't see a wiring problem and I'm asking for someone to tell me where the problem is.
Old 2nd December 2005, 08:20 PM   #13
Greg Erskine's Avatar
Originally posted by janneman
Apparently the red wire with the 4 leads is the center tap
Hi sumacSK,
As Jan has said, I suspect the red with 4 leads will be the CT and I guess it would be simple with a multimeter to work out which 2 belong to each secondary winding, then you will have 2 separate seondaries.
Usually the leads of transformers are insulated with enamel and only the last 15 or 20 mm is stripped for soldering. Check the insulation of each of the CT leads and use a multimeter to check that there is no connection between all the 4 leads.
regards
Greg Erskine
Old 5th December 2005, 02:09 AM   #14
john65b is offline john65b  United States
john65b's Avatar
Default Tried it...
MrLots2do:
I did the very thing you said thinking "it's gotta work". I wired it up with the cetertap to both connectors. I measured the correct +/- voltage prior to connecting the amp. But once I connected the amp, a fuse would blow (I have fuses on the Hot and Neutral - kept blowing the Neutral). I went through 12 fuses in two days before I just removed the extra four diodes and jumpered the missing diodes. Works fine now. I would hate to think what would have happened had I not had the fuse.
Why don't you try it, you realize it won't work correctly.
My 2 cents
Old 5th December 2005, 03:49 AM   #15
neutron7's Avatar
if you try to use a CT transformer with the center tap connected to both sides of a dual rectifier board, you will cause a short on half the cycle. the short actually is through some of the diodes. and the common ground. so it might appear to work untill you hook up the amplifier.
either use it with 4 diodes as a single bridge circuit, or, you can modify your transformer to dual secondary. i did the latter, and it worked fine but BE CAREFUL! I would not want anyone to ruin a perfectly good transformer or zap themselves.
Old 5th December 2005, 11:59 AM   #16
mrlots2do's Avatar
Default Re: Tried it...
Didn't see the micro-short (as I'm calling it) until you described it in detail, thanks John65b. Built a 4 diode rectifier board after reading your writeup. What I did come to realize was only a single rectifier is needed per power supply secondary. Quess I could build more amps now that I have extra rectifier pcb parts.
Thanks again
Transformer wiring roadie Solid State 2 23rd June 2009 03:33 PM
Transformer wiring problem ebenai Chip Amps 3 7th May 2007 06:56 PM
Push Pull Output Transformer wiring problem cyl Tubes / Valves 8 25th April 2007 02:23 AM
Transformer wiring zlast Solid State 2 18th May 2006 10:31 PM
Wiring of a transformer AudioFreak Parts 20 20th January 2002 02:40 PM
Copyright 1999-2017 diyAudio
