| Chip Amps Amplifiers based on integrated circuits |
#11 |
I ordered 35 chips from Jameco,all the chips worked. It is unlikely that the chips are the problem.
#12 |
Can't see anything obvious, unless the chip is blown...
Have you tied removing the chip from the PCB and measuring the voltage at the pin's holes? |
#13 | |
with the chip in place im getting pin 10 -20v pin 9 -20.8v pin 1 28.2v pin 4 -28.4v pin 5 25.2v *edit* i have no other boards to test. Since i only bought enough to build 2 of didi's amps, with some extra parts. would a 47uf be that big of a difference vs the 4.7uf digi has listed to test?
"I Love To Camp!" "Comensing Shock Therapy!" |
#14 |
would the wattage of the res. @220k matter? i wanted to use dales res. so i had to get a higher wattage 220k it is 2 or 3 watts.... if thats the problem i have phoneix 220k ones on hand.
#15 |
yes 47ufd would be too big, not that I'd think it would stop the sound.
Can you possibly get the circuit diagrame for this one...? If the resistor doesn't catch fire (lol), it should be ok. |
#16 |
had to do some digging but here is digi's work.
3886IGC protel layout share and just in case for further looking PCB based invert 3886 chipamp assembly and comments digi has his working and i just dont know where i went wrong or if something is dead/wrong.
| digi-key resistor ??? | jeapel | Pass Labs | 9 | 1st January 2006 01:00 AM |
| DIGI 125 - right VAS selection | Greg Erskine | Solid State | 15 | 15th July 2004 09:05 PM |
| where is modified DIGI-125? | palesha | Solid State | 4 | 3rd June 2004 03:48 AM |
| Digi 125 | tomcat | Solid State | 0 | 15th May 2002 09:52 PM |
| Page generated in 0.08834 seconds (72.72% PHP - 27.28% MySQL) with 10 queries |
