dc operated stereo volume control
Old 30th November 2005, 03:01 PM   #1
steven344 is offline steven344  United States
steven344's Avatar
Default dc operated stereo volume control
I wanted to build a dc operated volume control using one pot to control 2 channels,I came up with a circuit using fets and op amps,does anyone have ideas,I dont want to use the national chip
Old 30th November 2005, 03:13 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
If you give us your diagram we can at least point out the areas for improvement
Did you look in the VCA's from THAT corporation?
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 30th November 2005, 04:30 PM   #3
RCBandwidth is offline RCBandwidth  United States
RCBandwidth's Avatar
Default DC controlled pre-amp
Steven344: I built a very good pre-amp from the Analog Devices SSM2164(Quad VGA).You can implement full Class A operation by adding a single resistor.You can follow the circuit in figure 24 as a good starting point.
Regards Bob C.
http://www.analog.com/UploadedFiles/...786ssm2164.pdf
Old 1st December 2005, 12:28 PM   #4
steven344's Avatar
Default preamp
Here is my preamp,Have not built it yet.My idea is to use one pot to control 2 channels,First op amp is unity gain to isolate the source second op amp is for gain and third is buffer.The fets provide a variable resistence to ground after the 1 k resistor before the gain circuit.I would like anyones input as to if its a good circuit
Old 1st December 2005, 12:40 PM   #5
jan.didden's Avatar
Interestingly!
Two initial comments:
If you use the FET in the gain opamp feedbak path (instead of R1 for instance) you can delete the U1 buffer, another less source of distortion! Same for U3, totally superfluous.
FETS are non-linear in this application. The accepted way of using them is to keep the signal across the FET less then a few 100 mV, and also to inject about half of the signal across the FET to its gate adding to the control voltage. You often see this in audio signal generators where a low distortion means is needed to stabilise the level in a control feedback loop.
Jan Didden
dc operated stereo volume controlHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Installing Stereo Volume Control On Patio! mideus Multi-Way 1 17th May 2006 04:39 AM
Niles in-wall stereo volume control (L-pad) orthoefer Swap Meet 1 9th May 2006 12:39 PM
dc operated volume control steven344 Chip Amps 1 1st December 2005 12:44 PM
Stereo volume control Adam M. Chip Amps 12 27th February 2004 10:51 AM
