Old 27th November 2005, 02:50 PM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default Simple LM4780 Question
I could answet this in about 30 seconds if I had one sitting in front of me, but I don't.
Here it is: The pin-out diagram on the LM4780 shows two pins labled "GND". Is there continuity between these or not? I.e., is there an independant ground for each device in the package?
Old 27th November 2005, 03:34 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The GND (pin 12 and 19) are not internally connected.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th November 2005, 03:58 PM   #3
sam9's Avatar
Thanks. That is good to know (and what I was hoping to hear).
Old 27th November 2005, 04:03 PM   #4
sam9's Avatar
Not being real awake yet this morning, I forgot to as further which GND pin serves device A and which B. From the pinout diagram I would guess pin 12 is most likely A and 19 B, but there is no certainty of that.
Old 27th November 2005, 04:08 PM   #5
I can't be sure of that either, as in my implementation both grounds are connected anyway so I didn't really investigate that issue.
www.audiosector.com
Old 27th November 2005, 06:29 PM   #6
sam9's Avatar
I can work that out when the pieces arrive. The intent is for an HT amplifier (Lm4780x3 +LM3886x1). With everything all on one PCB my thought was that every effort to keep each channel as isolated as possible would be a good idea especially as it will double for ordinary music playback as well. I think I will have to see what kind of mess results when I lay out the PCB -- whether independant grounds or a single common one is more practical. Power bypass ground will definately be a separate net, however.
6 channel LM4780 question Wynand Chip Amps 18 24th November 2005 01:58 PM
LM4780 Question hongrn Chip Amps 4 14th October 2005 10:03 PM
Question about Lm4780 kit G.L. Tirebiter Chip Amps 1 5th March 2005 12:43 PM
Simple LM4780 question... los_ren Chip Amps 4 4th October 2004 09:18 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
Page generated in 0.06703 seconds (79.05% PHP - 20.95% MySQL) with 10 queries
