Old 27th November 2005, 02:51 PM   #1
Katapum is offline Katapum  Europe
Default What’s the minimum power transformer required to build a gainclone amplifier?
Hi all,
I have two power transformers with 2 separated winding each (2x12V/3.33A +2x12V/3.33A). Is it enough to build an inverted gainclone (Thorsten style)?
Any comments or suggestions are very welcome.
Katapum
Old 27th November 2005, 08:17 PM   #2
neutron7's Avatar
if you can get 2x24v 3.3a each thats about 160 VA which should be enough for stereo pair. or use one each side if you prefer . then you will have power to spare.
Old 27th November 2005, 10:18 PM   #3
Just to clarify I have two power transformers:
One (two separated windings and no centred tap):
12Vac/3.3A
12Vac/3.3A
Another (two separated windings and no centred tap):
12Vac/3.3A
12Vac/3.3A
I don´t have any 24Vac transformer.
(att. IGC schematic)
Katapum
Old 27th November 2005, 11:05 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
They might do if your average output power is far from 100%. If the transformers are getting real hot they are probably too small for your needs.
If I understand you right you have two transformers of 80 VA each. This will do. I'm quite convinced of it.
/Per-Anders (my first name) or P-A as my friends call me
Old 27th November 2005, 11:28 PM   #5
tja is offline tja  Netherlands
12Vac/3.3A
12Vac/3.3A
12Vac/3.3A
12Vac/3.3A
Put the secondaries of each transformer in series, that will give you two transformers with 24V. One for + and one for -.
Take
Old 28th November 2005, 02:43 AM   #6
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
AC12V from a transfomer still sufficient to power a gainclone,only the output power get reduced.
Old 28th November 2005, 06:37 AM   #7
neutron7's Avatar
if you do as Tja said
you can use the transformers together to be equivelant to a 160 VA 24 + 24 which will work very well.
you have to connect the 2 winding of each transformer in series, so you will need to make sure you know the phase.
Old 28th November 2005, 10:49 AM   #8
Hi all,
I built the amplifier. It’s incredible bad. I need to turn the pot at 3 o’clock to get some power (but not too much). Maybe I have done something wrong. The amplifier worked with 95dB diy open baffle speakers.
I have also a 300B tube amplifier (9W) and it has much more power.
What do you think?
Amplifier also has a little hum problem but I think it’s because the power input is too near input line and output speakers. Am I right?
How can find winding transformer phase (I have only a DMM)?
Katapum
Old 28th November 2005, 10:54 AM   #9
How did you wire the transformers?
Take
Old 28th November 2005, 11:00 AM   #10
Katapum
Power Amp build bits - guidance required... ix66 Solid State 63 24th September 2011 07:58 PM
Need advice - what can I build with this power transformer? zobsky Tubes / Valves 6 22nd March 2007 01:47 AM
Gainclone power supply transformer - Help! DJ Exprice Chip Amps 17 2nd July 2006 06:40 AM
LM3875, minimum input sensitivity (gainclone) mAJORD Chip Amps 4 22nd April 2004 06:42 AM
I have an odd transformer issue (want to build the gainclone) Jerry Parker Chip Amps 9 22nd October 2003 01:37 AM
Page generated in 0.11044 seconds (77.92% PHP - 22.08% MySQL) with 11 queries
