| Chip Amps Amplifiers based on integrated circuits |
#21 | |
I attached my dacs buffer. When I made my dac I only connected input AC filter and transformers screens to chassis so I didn´t connected to chassis any star grounds PCBs. is it a good procedure??? Katapum |
#22 |
hello and greetings,
I have this transformer that is looking for a new home. It has 2 secondaries measuring 15 v ac, 20 v dc-no load. so about 19v dc. I have built all kit amps and this will be my 1st point to point project. Any suggestions for a good sounding, project? and schematic? Trying to keep the cost within reason and parts count low ; something similar to the original gaincard. The chips I have used are: lm3875, lm4780, lm3886. I have an enclosure in mind; it's going to be cube shaped. cheers doggy
#23 |
I think I will use the lm3886; it's spec.'d to go as low as 18 volts; maybe try to build a good capacitor supply feeding smaller caps. near the chip. plan to use 4 diodes for rectifier.
should be a fun project, doggy
#24 | ||||
Help me please? Katapum |
| Power Amp build bits - guidance required... | ix66 | Solid State | 63 | 24th September 2011 07:58 PM |
| Need advice - what can I build with this power transformer? | zobsky | Tubes / Valves | 6 | 22nd March 2007 01:47 AM |
| Gainclone power supply transformer - Help! | DJ Exprice | Chip Amps | 17 | 2nd July 2006 06:40 AM |
| LM3875, minimum input sensitivity (gainclone) | mAJORD | Chip Amps | 4 | 22nd April 2004 06:42 AM |
| I have an odd transformer issue (want to build the gainclone) | Jerry Parker | Chip Amps | 9 | 22nd October 2003 01:37 AM |
| Page generated in 0.08248 seconds (74.05% PHP - 25.95% MySQL) with 11 queries |
