What’s the minimum power transformer required to build a gainclone amplifier? - Page 2 - diyAudio
Old 28th November 2005, 10:18 AM   #11
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Just for general info, I have a mono 3875 running on a 20VA 15-0-15 that I use for speaker testing. It easily drives any driver to reasonable listening levels.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th November 2005, 11:31 AM   #12
Jay is offline Jay  Indonesia
Banned
Hi Katapum,
12V secondary (AC) will give you about 16V rail (DC). Check the chip documentation (rail voltage vs power), I think 12VAC will give you at least 12W, and with your sensitive speaker this may be enough. You can improve a bit tho by using pre-amp.
But you can also get 24V secondary by connecting two 12V secondaries together. So, two 12V secondaries become one 24V secondary. Simply connect the 2 centermost cables of the 0-12V-0-12V to get 0-24V (Then you can connect the 2 transformers to get for example 24V-CT-24V). If you cannot locate the centermost cables, make sure you can locate each secondary of 0-12V (different secondaries have no interconnection so no voltage between them) and then simply try any connection between 2 secondaries and measure the output. If you get 24V, you don't have phase problem.
Old 28th November 2005, 09:24 PM   #13
Katapum is offline Katapum  Europe
Hi all,
I measured V+ and V- at 1000uF caps and I found:
+16,4V
-16,3V
+15,7V
-15,5V
PSU is ok.
I also measured 100K pot (connected) I found: 82K.
I don’t know what’s happen with my GC. I think it has less then 5W.
Katapum
Old 29th November 2005, 04:27 AM   #14
rampage101 is offline rampage101  Australia
Send a message via ICQ to rampage101 Send a message via MSN to rampage101
Have you got all three wires of the pot hooked up correctly?
What's a signiture?
Old 29th November 2005, 07:48 AM   #15
Big question could you check it for me?
PS: It´s a linear 100k pot.
Katapum
Old 29th November 2005, 09:12 AM   #16
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
i could not but notice you used pieces of perf board for the chip amps.
I'd check if you did not switch input and feedback resistor.
If you did, max output voltage would not be 16 volts but 1/16th.
If your loudspeakers are really that sensitive you'd still have them produce sound with such extreme feedback.
At first i used 300VA toroids for the GC kits i got from BrianGT.
Then switched to 225VA, 160VA and 80VA per channel.
imo, can't say that using bigger toroids is worth it.
Tried the GCs on junk speakers first, then big 90 dB/W vifa's, then 86 dB/W ELS63s.
Plenty power on 25Vac, 22Vac and 18Vac.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 29th November 2005, 01:36 PM   #17
Banned
Hi katapum, I cannot see why there could be a problem with potensio. I don't remember the concept of this inverted topology, it's just that the circuit looks strange to me. But if there is something wrong with the circuit, jacco must have noticed that. So the possibility is you put wrong resistor at wrong position, like jacco would like you to check.
Old 29th November 2005, 10:15 PM   #18
I checked the entire amplifier and I think everything’s ok except the ground speakers wire. I have connected speakers ground to signal ground. So I fixed it.
Next I made two tests.
First test system:
Cdplayer
Dac (diy)
Gainclone
Speakers
It sounds very low (no power), big hum, bzzzz, ….., many noise, …...
Second test system:
Cdplayer
Dac (diy)
TVC (transformer volume control, gain=+6db)
Gainclone
Speakers
It sounds very good, a lot of power, almost no noise.
So I think gainclone has a ground problem. What do you think?
How can I fix it? (I´m a newbie).
Katapum
Old 29th November 2005, 11:22 PM   #19
pinkmouse's Avatar
Might be an impedance mismatch between your DAC and gainclone, what design is it, ( the DAC)?
Old 30th November 2005, 07:23 AM   #20
dac
Katapum
Power Amp build bits - guidance required... ix66 Solid State 63 24th September 2011 06:58 PM
Need advice - what can I build with this power transformer? zobsky Tubes / Valves 6 22nd March 2007 12:47 AM
Gainclone power supply transformer - Help! DJ Exprice Chip Amps 17 2nd July 2006 05:40 AM
LM3875, minimum input sensitivity (gainclone) mAJORD Chip Amps 4 22nd April 2004 05:42 AM
I have an odd transformer issue (want to build the gainclone) Jerry Parker Chip Amps 9 22nd October 2003 12:37 AM
Copyright ©1999-2017 diyAudio
