| Chip Amps Amplifiers based on integrated circuits |
I've read about the delayed relay that shorts the output to ground until the crossover has had time to warm up.
What other methods are available? One idea is that I might power the crossover directly from its own unswitched supply, so it stays on all the time that the amp is plugged in. Of course, plugging in while switched on or power outages might cause pops. Is the start up noise just a nuisance or potentially driver damaging? My current set-up has 4" full ranger without a tweeter if that makes a difference. |
#2 |
Did it Himself
The best thing to do is add DC protection and delay muting to your power amps outputs. If you are using a decent bought amp this feature will be already present. Then just switch your stuff on/off in the right order.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Electrons are yellow and more is better!
If you don't have any problems with power up you don't need to do anything about it. Minor startup transisents won't hurt the speaker. If you buiuld a gianlcine and do it right you'll get a totally silent turn on and turn off.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
OK then, I'll try without anything (on test speakers) and come back if I do have noises.
#5 |
If you are using any of the LM chips that have built in mutes, you can just add a slow start with an extra cap and resistor. See the LM4780 datatsheet for details.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
hmmm, a good reason to buy another lm3886 kit. At the moment I've got 1x3875 and 1x3886.
#7 | |
| Soft Start Necessary? | dtaylo3 | Class D | 2 | 26th December 2008 09:05 AM |
| B+ soft start | Gluca | Tubes / Valves | 2 | 3rd September 2007 01:04 PM |
| Need a soft start? | maxpou | Solid State | 19 | 18th April 2007 09:23 PM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 03:32 PM |
| Page generated in 0.08336 seconds (76.30% PHP - 23.70% MySQL) with 10 queries |
