Old 24th November 2005, 10:48 AM   #1
Send a message via ICQ to rampage101 Send a message via MSN to rampage101
Default Really Warm Gainlcone
At the moment my LM3886 chips are mounted on a piece of 3mm 50mm wide Angle Alloy. But the alloy is getting really really warm, to the point where I can't leave my hand on the alloy. Is this normal? Do I need better heatsinking? Or could this be oscilating?
Specs:
2x18vac 300va Transformer,
Carlosfm Snubberized PSU MkII (2.2k -> 10,000uf - > 100nF - > 1R + 100nF).
LM3886 with 1500uF 35v Electro's at psu pins.
Original BrianGT kit values (220Ohm, 22k, 22k, 680ohm) plus 10k mute.
So, any ideas? Sound is great, I would never complain of the quality. And whilst the amp was getting hot its only started getting this hot tonight since doing the better psu instead of just 6x1500uF (3x per rail)
What's a signiture?
Old 24th November 2005, 12:04 PM   #2
pinkmouse's Avatar
Oscillation probably.
Can you put it on a scope? What happens if you disconnect the new PSU? Does it still got hot with the input shorted to ground?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 24th November 2005, 01:07 PM   #3
Banned
Default Re: Really Warm Gainlcone
PSU voltage is more stable now, and the chip dissipates more heat.
At idle it should make no difference, but when playing music, yes.
Those heatsinks are small
Old 24th November 2005, 02:01 PM   #4
pinkmouse's Avatar
Default Re: Re: Really Warm Gainlcone
Could you explain in more detail?
BTW I have a 3886 running right next to me now on an 18V traffo on similar heatsinks and it's perfectly cool.
Al
Old 24th November 2005, 03:06 PM   #5
Banned
Default Re: Re: Re: Really Warm Gainlcone
On the more difficult/demanding musical transients the PSU voltage sags, with lower capacitance.
As the PSU voltage drops, the chip has less heat to dissipate.
Are you sure you have similar heatsinks?
3mm is very thin, specially without fins.
And 50mm wide is two inches, have you noticed that?
Unless I didn't understand and those 50mm is just the size of the L shaped bar and he is not specifying the width.
Old 24th November 2005, 04:08 PM   #6
pinkmouse's Avatar
Thanks Carlos, I'm not sure how much effect that would have at normal listening levels though.
Mine is a stereo amp, with seperate supply, and the bottom of the case is used as a heatsink. It's 3mm thick ally plate, roughly 80mm by 60mm.
Al
Old 24th November 2005, 09:03 PM   #7
The angle is 50mm, so 50mm heigh, 50mm wide, 3mm thick, and about 250mm long altogether.
What's a signiture?
Old 24th November 2005, 11:11 PM   #8
Banned
Still, 3mm is thin. It makes a 'hot-spot' on the back of each chip, heat doesn't spread properly.
Results depend on your speakers.
If you have difficult speakers, it can get quite hot, even at that voltage.
Old 24th November 2005, 11:46 PM   #9
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Question Oscillations...
All my clones, single, paralelled & bridged have had ocillation-problems when first tested...
Even the BG kit ones. And all done "by the book".
So, now I always make an output inductor, 10-12 rounds of 0,8mm trafo-wire around an "AAA" battery, paralell with a 8-10 ohm 3W resistor. This have cured all my osc. problems.
Arne K
Ars longa, vita brevis
Old 25th November 2005, 12:17 AM   #10
Well in this case carlos, assuming its my speakers are too difficult, how do I get 12v from my 25v line to run a fan? I don't want another trafo in there.
What's a signiture?
Help!!ETD core warm Xaudiophile Power Supplies 9 19th May 2005 04:49 PM
SI T-amp warm-up? irss Class D 3 8th April 2005 11:40 PM
My amp gets warm... Jye Multi-Way 6 21st November 2003 11:53 PM
I/V OPA627's getting warm?? MWP Digital Source 6 17th September 2003 10:37 AM
Page generated in 0.14263 seconds (72.81% PHP - 27.19% MySQL) with 11 queries
