My active preamp/tone-control and TL074
Old 11th July 2009, 01:16 PM   #21
akis is offline akis  United Kingdom
I had a look at the schematic at the top and it appears strange. There is positive feedback on the two stages? How is that meant to work?
Also it appears we are presenting a 120K-ish resistance to the input source but only using 1/4 of it, 75% wasted. Then the tone circuit is grounded with a 750 R resistor right after it has come through 3K resistors at its best settings, how is that designed to work?
Old 23rd July 2010, 04:29 PM   #22
hipanni is offline hipanni  India
Default tone control
hi, this is kannan,
i need clear sound from stk ic. please give me your tone control circuits or any audio circuits. I am already used tda1524, ka2107,ka22233 ic and elliots project no 97, and three band tone control in different op amps but i am not satisfied.
Old 23rd July 2010, 04:59 PM   #23
teleman is offline teleman  Norway
The tone control circuit is already there in my post.use a Fairchild/Texas or any NE5532 IC only,which works far better on tone controls IMO. You may have to scale it up or down by changing the nework resistors & caps to get the required gain.
If you are not happy with the "tone control circuit you're using,then why don't you search for some on the web? There are plenty of them for the picking!
Old 23rd July 2010, 05:07 PM   #24
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hey diyers
greetings tone control for my dx blameless mid base treble balance volume and mic input tlo72
thanking you
andrew lebon
Old 26th February 2011, 06:46 PM   #25
wattaniya is offline wattaniya
Originally Posted by andrewlebon View Post
hey diyers
thanking you
andrew lebon
can u share tone control pcb layout in pdf format.
Old 28th February 2011, 10:01 AM   #26
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
you can have a look at my digital tone control also , everything works through a menu driven interface and using a single rotary control knob.
LM4780 paralell pcb
Old 2nd March 2011, 06:54 AM   #27
hi friends i want circuit diagrams
by
kannaa
Old 13th June 2011, 02:54 PM   #28
Originally Posted by Mooly View Post
The TL072 series is capable of trully excellent sonic performance.
With the very greatest respect I would suggest you need to look elsewhere in your audio setup.
hi, i have TDA 7294 amp. i need tone control for this amp. LM 1036 is not available in my city. TDA 1524 is noisy. so please send me true sound tone control circuits
My active preamp/tone-control and TL074Hide this!Advertise here!
Active filter/Tone control Amagic Analog Line Level 6 26th October 2016 03:32 AM
adding tone control to active crossover Dan2 Solid State 5 5th December 2008 03:35 PM
Baxandall active tone control jenks Solid State 3 18th April 2008 10:18 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
3-Ch LM3875 w/ Tone Control and Active Crossover StalfoS Chip Amps 6 11th January 2005 01:54 AM
Copyright ©1999-2017 diyAudio
