Old 21st November 2005, 06:11 PM   #1
steven344's Avatar
Default Gainclone speakers
Here are some speakers Im working on with built in gainclones in the pedastal
Old 21st November 2005, 06:12 PM   #2
steven344's Avatar
Default inside pedastal
Inside the bottom of speaker
Old 21st November 2005, 06:20 PM   #3
bigwill is offline bigwill  United Kingdom
That's interesting, I've been thinking about using CPU coolers as heatsinks for a gainclone for a while now. How well does it work? Is it worth doing?
Speakers look great btw
Old 21st November 2005, 07:11 PM   #4
Send a message via MSN to youyoung21147
Cool idea to put the amps in the bottom ! You don't have to drive long wires that reduce damping factor !
Isn't it getting hot inside ? I see no hole for the air to pass through the base
Those LM4780 are getting hot, and your speakers look quite hard to drive (nice woofers BTW)
Old 21st November 2005, 07:56 PM   #5
steven344's Avatar
Default another view to see the fan in back
Fan hole in back
Old 22nd November 2005, 05:24 AM   #6
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
I think what he was referring to is that you have air coming into the box via the fan, but where does the air exit?
The power of Science compels you!
Old 22nd November 2005, 08:32 AM   #7
owen is offline owen  United Kingdom
Looking at the picures - there is no 'bottom' to the compartment...
Owen
Old 22nd November 2005, 11:43 AM   #8
Steven344 where did you get those transformers?
Old 22nd November 2005, 12:36 PM   #9
steven344's Avatar
Default gainclone speakers
Im still working on these along with six other projects,Still have to cut a hole for fan exhaust and add fan control circuit to keep things quiet plus add a bottom.The transformers are out of mits vcrs the should have enough power,I like to recycle alot of good stuff goes in the landfill.I found 6 of these vcrs in the garbage and took the transformers out,they also had useful parts in the power supply like caps,regulators and bridge rects,Alot of older vcrs had high current transformers to drive the big motors.I used the same transformers in my tubeclones
Old 22nd November 2005, 03:47 PM   #10
analog_sa's Avatar
some vibration-control proponents can have nightmares after seeing this pic
My GainClone is Blowing up Speakers Arunkumar14_th Chip Amps 17 28th January 2009 02:19 PM
100V Speakers and the GainClone Amp. McKiltie Everything Else 7 9th September 2007 09:24 PM
Speakers for Gainclone hotscot Chip Amps 6 2nd February 2006 05:05 AM
Efficient DIY speakers for gainclone under or around $300 US? TheDriver41 Multi-Way 25 25th September 2004 04:18 AM
HT speakers to pair with a gainclone? AJ Bertelson Chip Amps 7 3rd January 2004 11:11 AM
Page generated in 0.08973 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
