Lm3875 Rev C
Lm3875 Rev C
Old 21st November 2005, 05:44 PM   #1
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
Default Lm3875 Rev C
Hi all,
I know that it has been discussed many times before but I still have some obscurities. I ordered Non-Inverting LM3875 rev.3 Stereo Kit. My Q's are: What are those optional rezistor and capacitor for? Whether should I use them? Next thing, there are only doides and capacitors for PSB, is it all what I need for PSB?
Maybe if somebody has a picture of asembled circuit boards it could be very usefull.
Thats all for now, thanks Martin
Old 21st November 2005, 06:27 PM   #2
javven is offline javven  United States
It sounds like you have one of Brian's kits.
The optional resistor and cap are discussed somewhat on Brian's page (look for the LM3875 construction PDF's).
The recifier PCB only does have some recifier diodes and caps. That's all it seems to need. There is the 'snubberized psu' option, though. If you were looking for 3000uF + filter caps on the PSU, the snubberized version is where you'll find them. Read up on the 3886 construction and the snubberized PSU, same site.
I was surprised the snubberized kit helps as much as some folks seem to be saying - but it may be worth the build. I'm building both and comparing.
Old 21st November 2005, 06:59 PM   #3
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Lm3875 Rev C Send a message via AIM to Peter Daniel
Brian's LM3875 board is similar to what I'm using. This schematic may be helpful: http://www.audiosector.com/lm4780%20psu.pdf
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 22nd November 2005, 12:04 AM   #4
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Re: Lm3875 Rev C
Originally posted by sumacSK
Hi all,
Martin,
Peter's schematic should explain the extra component placements on the pcb. The standard configuration is the one in the users guide for the LM3875. I am guessing that you bought it from him, as my kits have only been shipping out for US orders.
As for assembled pictures of the boards, if you are to use the extra components for the snubberized supply, it should look something like this:
I found it best to solder the large caps in last (including input/output wiring), as they are the only component mounted on the bottom of the pcb.
Best of luck with your project,
Brian
Old 22nd November 2005, 12:29 AM   #5
GringoAudio is offline GringoAudio  Canada
Hi all,
..... Next thing, there are only doides and capacitors for PSB, is it all what I need for PSB?
Maybe if somebody has a picture of asembled circuit boards it could be very usefull......
You need a transformer too.
Old 22nd November 2005, 09:28 AM   #6
Hi all,
THANKS! everyone for your help.
Brian, I bought it from you- I've been to US couple of monhts ago.
So if I understand it correctly I can build recifier PCB with only those diodes and caps (maybe I'll add those components to make it snubberized later). But I'm still unsure about those optional Cz and Rz on amplifier PCB. They should be used only when snubberized supply is used or is it a zobel network, or... ?? I'm confused..
And the last Q is: do I have to (also on Rev.3 board) solder the NFB resistor directly to the pins of the chip? Or it is that Rf resistor?
Thanks again Martin
Old 22nd November 2005, 11:29 AM   #7
BrianGT's Avatar
Hi all,
Thanks again Martin
For the power supply board, you can always build it with the standard configuration and upgrade later.
As for the the feedback resistor, Rf, you can mount it on the pcb, or mount it on the chip directly. It is your choice.
As for the Rz and Cz, there are the optional zobel components, a 2.7ohm 2w resistor and a 0.1uf cap.
Brian
Old 22nd November 2005, 11:35 AM   #8
Thanks Brian, now everything seems to be clear..
Thank you. Martin
Old 22nd November 2005, 11:45 AM   #9
BrianGT's Avatar
Thank you. Martin
Great! Best of luck on your project.
Brian
Old 22nd November 2005, 05:37 PM   #10
Grandma´s_SUB is offline Grandma´s_SUB  Europe
maybe offtopic;
Why is my GC mini buzzing(not loud)?
I connected all GNDs to one point(speaker,pc out,chip...-aka star connection),I have 2x1000uF caps per a chip-directly mounted,2x28V on secondary...
See below for schematic
NOTE:I didnt add 1,5K optional resistor
Lm3875 Rev CHide this!Advertise here!
yet one more lm3875 karma Chip Amps 8 27th July 2005 08:48 PM
WTB: LM3875 pcb vdi_nenna Swap Meet 7 27th July 2005 03:19 PM
LM3875 into 4 Ohm audioPT Chip Amps 12 7th July 2005 12:14 AM
LM3875 60W Amp juiceman Chip Amps 3 18th February 2005 06:28 PM
What LM3875 to buy? AJ Bertelson Chip Amps 12 18th January 2004 02:40 PM
Copyright ©1999-2017 diyAudio
