Old 20th November 2005, 07:53 PM   #1
Padel is offline Padel  Greece
Padel's Avatar
Default I need advise for three channel Parallel LM4780 project.
Hi all,
I'm building two, three chanells amplifiers based on parallel LM4780 chips for my three way speakers.
Just completed the amplifier and power supply boards, I choose high capacitance (10000uF) for the bass amplifiers and low capacitance (1000uF) for the mid and tremble amplifiers. Each amplifier module has its own Power supply PCB.
I still need enclosures and power transormers.
Sound wise, is there any good reason not to use a single transformer (24v+24v secondaries @ 1000VA) to supply all three PS modules and amplifiers?
Is it better to use different secondaries (i.e. 24v+24v+24v+24v+24v+24v @ 1000VA) for each module and even better to use different transformers?
P
Old 20th November 2005, 07:55 PM   #2
pinkmouse's Avatar
I would go for two traffos, one driving the woofers, and the other the mids and highs.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 20th November 2005, 07:58 PM   #3
Padel's Avatar
Is this going to be better than multiple secondaries?
Thanks for the reply.
P
Old 21st November 2005, 04:07 PM   #4
Padel's Avatar
Anyone???
Old 21st November 2005, 04:49 PM   #5
UrSv is online now UrSv  Sweden
UrSv's Avatar
I would go for the big transformer but run separate bridges.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 21st November 2005, 11:39 PM   #6
Padel's Avatar
This what I'm thinking, but would I have the full advantages of tri-amp this way?
P
Old 21st November 2005, 11:53 PM   #7
moamps is offline moamps  Croatia
My vote goes to:
two monoblocks,
two transformers in a each monoblock; bass + mid/high.
Milan
Old 22nd November 2005, 12:07 AM   #8
Padel's Avatar
Originally posted by moamps
My vote goes to:
two monoblocks,
Milan
It is two monoblocks, three channels each.
P
Old 22nd November 2005, 12:27 AM   #9
Banned
Default Re: I need advise for three channel Parallel LM4780 project.
Different secondaries is better.
Even better is separate transformer for each drive unit/amp/channel.
That would give you two trafos (one per channer) with 6 24V secondaries each, or (even better) 6 trafos with 2x24V each.
As you already have independent PSUs for each amp, it's just a question of trafos.
And that depend$ on how much you wanna $pend.
LM4780 in parallel...? j.wright Chip Amps 9 9th June 2008 10:24 PM
FS: 4 Channel Parallel LM4780 gainclone Matt_Tillard Swap Meet 8 10th January 2007 09:08 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
==>> Parallel 4x LM3875 for 2 ohm speaker - pls advise.. metha Chip Amps 24 18th April 2004 09:29 PM
Help! Parallel 2x 3875 per channel design - please advise. loong Chip Amps 23 3rd April 2004 11:08 PM
Page generated in 0.10591 seconds (75.95% PHP - 24.05% MySQL) with 10 queries
