| Chip Amps Amplifiers based on integrated circuits |
I'm not really sure where I should have posted this, but anyway...
I have a the SUB-250R subwoofer amplifier from Solen which is the same design as the smaller subwoofer amplifiers you will find at Parts Express, ApexJr, and Rythmik Audio. The problem I have with the amplfier is that it will not automatically turn on when the volume is at a very low level. In fact it is quite annoying in that the turn on level for this amp is at the point where if I watch TV at a normal volume, the sub will turn off during the show, and turn on during the ads (which are louder). Is there a possibility to change a part or two in the input module to increase this amplifiers auto turn-on sensitivity? It has been a few years since I have worked with transistor circuits, so I'm not really sure about this circuit. You'll see the on-auto-off switch in the lower left of the following image:
The power of Science compels you! |
#2 |
Use higher value for R37 or/and smaller value for R36. Also, if the timeout is too short, use higher value for C19 and/or higher value for R46. Regards, Milan |
#3 |
Change that voltage divider, got it. Thanks.
It'll be a few days before I will have the time to test it out, but I'll let you know how things work out. Something like double the value of R37, and half the value of R36 should work out, as long as the sensitivity is not so low that the amp is being turned on by line noise.
#4 |
Crap. My PCB, having the model with the remote control, has different designation numbers for the resistors. I guess I am out of luck for this modification.
#5 |
just another
maybe not all is lost
I'd assume that the remote basically controls the level of the sub??? meaning that the rest of the circuit is probably the same??? how many 2.7K resistors are there in series with a 20K resistor (with pin 2 of an opamp connected to the middle) in the circuit?? without checking the entire schematic I'd guess probbaly only the one!! should be relatively easy to track it down on the pcb, and then a bit of tracing should show you whether you are in the right spot...Tony. |
#6 |
Did it Himself
moamps you got that the wrong way round. The 2.7k (I thought it was 2.7M but doesn't really matter) should be made smaller to increase the gain.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
just another
maybe it is 2.7M I had trouble readning the value on the schematic, and made no attempt to work out the actual circuit
![]() Tony. |
#8 |
Yea, I'm sure with a little looking around on the PCB I could find the resistors. R36 and R37 on my board are at almost opposite ends on my board, which is odd because I used the same schematic to remove the bass-boost on this amp and the resistors had the same designation. Hopefully I will have some time today to look at it.
#9 |
Did it Himself
Just check that what you are removing is a 2.7k or 2.7M resistor
#10 |
R36 is definately and M, and R37 is most likely and M. They better both be M's because that's the size of resistors I grabbed from school today. I'm looking at the board right now. Stay tuned
| Harman Kardon PA 2000 auto turn on input sensitivity | MisterTwister | Solid State | 0 | 8th April 2007 03:22 AM |
| Increasing amplifier load. | Freestyling | Multi-Way | 1 | 5th February 2007 11:17 PM |
| increasing the sensitivity of an auto on sub amp | pjpoes | Subwoofers | 0 | 21st January 2007 12:55 AM |
| Modifying auto power on sensitivity? | Sillyboy | Parts | 3 | 2nd July 2006 04:31 PM |
| Increasing Power Output of a Car amplifier | Dj BASS AMP | Solid State | 5 | 5th October 2002 11:37 PM |
| Page generated in 0.13799 seconds (61.65% PHP - 38.35% MySQL) with 10 queries |
