| Chip Amps Amplifiers based on integrated circuits |
Hey all,
I am in the process of assembling my six channel amplifier for my 3 way active speaker project. I am using two 4780 in bridged mode to drive the woofers and two 4780s in parallel mode to drive the midranges while the 3886s are driving the tweeters. Before i finalise the layout and start assembling the amp, i want to know how to add an inexpensive and easy to build(with as little components as possible) DC speaker protection circuit with a soft start circuit for all six channels. I am using an active xover(http://www.siliconchip.com.au/cms/A_30278/article.html) along with a ALPS RK27 10k log pot as passive pre all in the same amplifier case. I would appreciate if you guys could give me suggestions on the speaker protection circuitry as the speakers are fairly expensive. Vifa D27s, Scan speak M13/8640 and Dayton classic 10s. Thanks, Sachi |
#2 |
Maybe look at http://sound.westhost.com/project33.htm for some starting ideas.
#3 |
Hey Nordic,
Have gone through that.. the number of compoenets for a six channel protection system would exceed the number of components i have used on all six gainclone boards.. Isn't there something more simple with a reduced component count. |
#4 |
Dunno man, the protection circuit in the Mauro amp also has like 3 transistors, some diodes and caps.. although the layout is quite compact, maybe fits in 3 x 2cm of PCB... have a look at the thread for the circuit... not sure though how much protection it offers as it also serves as a softstart, with relay.
The components you mention are small stuff like diodes and resistors, surely you could even fit it on a small bit of veroboard... |
#5 |
Thanks..will take a look at it..i assume ur referring to this thread
My "audiophile" LM3886 approach |
#6 |
#7 |
Thanks!
| NAD C320 Amp Protection delay help please | Kajman | Solid State | 2 | 15th December 2007 03:24 PM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| SPK protection delay to close circuit | ckwong99 | Solid State | 1 | 28th October 2005 03:09 PM |
| amp delay for speaker out | nucleus | Parts | 4 | 4th September 2004 12:09 PM |
| speaker-delay tip | Mr. Triatic | Everything Else | 1 | 2nd March 2002 10:02 PM |
| Page generated in 0.13683 seconds (54.97% PHP - 45.03% MySQL) with 10 queries |
