| Chip Amps Amplifiers based on integrated circuits |
#2 |
in such case u should use only 1 bridge and find schematics of a dual supply using single bridge. there are tonnes available on the net and ever here on the forum. |
#3 |
Make sure you connect the AC wires from the transformer to the pins marked ~ on the bridges... the + and - are the DC output pins.
I have used the circuit below, you may want to modify, adding the stuff before the transformer from your circuit... The diodes are 2 oversized jobbies, I think I used 2 8A ones, it can be low voltage units. ![]() The ground symbols marked with lines, is connected to the PSU case, and the mains earth wire also connects to the case R1 use 5W resistor Use plain ceramic for the 100nf cap as a short circuit to radio frequency signals, effectively grounding them. Above circuit desigend by Rod Elliot. |
#4 |
thanks for your answers.
i will be using this PSU for 1 bridged dual lm3886. for now i will use only 1 bridge. |
#5 |
Zaf, just check quickly as I edited the post a bit, with more info.
The circuit I showed should work with your transformer without issues. Remember the fuse has to be a slow-blow or T-fuse |
#6 |
thanks nordic.
I have another question.... my trafo is 18 0 18, and makes 26.5DC with the firsts caps & 2k2 ohms resistor (the ones who discharges the capacitors after psu shutdown). i have 2 caps rated 17000uf 25v, they're smaller than the other ones that i have (20000uf 75v). the biggers dont fit in my case, so I was wandering what will happens if I use the smallers (25v) with 26.5v. what do you think? 1.5V is a risk? |
#7 |
I wouldnt use the 25volt caps. It might work at first but it will fail. You want caps with working voltage of at least 1.4 times secondary voltage.
#8 |
I aggree with Jaudio, you will either have to find a biger case, or look for lower profile capacitors.
#9 | |
1.4 times !!! It means one wouldn't use some 40V caps on 34.5V (no load) rails ?! Caps lifetime is guaranted for the nominal voltage, and mainly depends of ripple current, according to datasheets. Is there a reason for this 1.4 factor ? |
#10 | ||
| correct box? | dallaire | Multi-Way | 2 | 31st December 2007 07:25 PM |
| is it correct to calculate OTL? | sam8888ysl | Tubes / Valves | 15 | 26th November 2007 05:48 AM |
| quasi correct sub eq | traw | Subwoofers | 2 | 23rd January 2006 05:16 AM |
| My PCB for DoZ, it correct? | mod_evil | Solid State | 4 | 4th October 2005 01:30 PM |
| Is WinISD correct? | mazeroth | Multi-Way | 9 | 2nd November 2004 02:40 PM |
| Page generated in 0.11506 seconds (70.23% PHP - 29.77% MySQL) with 10 queries |
