is this PSU correct?
Old 18th November 2005, 04:15 PM   #11
youyoung21147 is offline youyoung21147  France
Send a message via MSN to youyoung21147
ah OK I see : transformer secondaries*square root(2) to have the secondary DC voltage.
With 34.5VDC no load, you agree that there is no particular problem using 40V caps. Caps can moreover handle nominal voltage*1.15 surges for a short time.
Old 18th November 2005, 04:23 PM   #12
Nordic is offline Nordic  South Africa
Nordic's Avatar
They might work for you to test your PSU etc... but they will have a shorter lifespan than usual by quite a factor. So you would want to get some decent onces at the earliest opportunity...
If you want to sell for a profit, sure go for it, but if its for you, don't cheat yourself with substandard stuff.
Old 18th November 2005, 08:14 PM   #13
jaudio is offline jaudio
Youyoung21147 have you thought about a separate case for the power supply? It need only to be as big as your caps and transformer. If it a toroid transformer you can fasten it to the side of the case.
Old 18th November 2005, 08:24 PM   #14
Yes, I am doing a separated shielded case for the PSU right now. It is long to build as I have not much time yet.
My problem is not place, but rather money : 40V caps can be almost two times less expensive !
According to the datasheet, they can live 100'000h at :
- 0.7 ripple current
- 40V nominal voltage
- 40C
Old 18th November 2005, 09:38 PM   #15
Zafira1981 have you tried a separate case for power supply?
Old 18th November 2005, 10:33 PM   #16
zafira1981 is offline zafira1981  Argentina
Well, I have news.
I installed the siemens caps (20000x75v) and they really improved the bass response of the amp. I was using only 5000uF (1 for VCC and 1 for VEE).
i will not use the 20KuF caps because they're REALLY bigs, I 've looking for caps prices and i found 10000ufx50v at 3.672u$s each. so next week I will buy 4.
I dont want to buy a new case because they're expensive here... in argentina you have to multiply by 3 the prices. so each cap will cost like u$s11 each!!!
thanks!!!
is this PSU correct?Hide this!Advertise here!
correct box? dallaire Multi-Way 2 31st December 2007 07:25 PM
is it correct to calculate OTL? sam8888ysl Tubes / Valves 15 26th November 2007 05:48 AM
quasi correct sub eq traw Subwoofers 2 23rd January 2006 05:16 AM
My PCB for DoZ, it correct? mod_evil Solid State 4 4th October 2005 01:30 PM
Is WinISD correct? mazeroth Multi-Way 9 2nd November 2004 02:40 PM
