4780 producing only hum: help needed!
Old 17th November 2005, 08:48 AM   #1
zenocosini is offline zenocosini  Italy
Default 4780 producing only hum: help needed!
One amp of a dual mono kit from audiosector.com produces only a hum
and few music only when volume is tourned at max.
The voltage between the speaker pole is +12 mV
I suspect I bourned the chip because before I put it into a case everything was ok ( but I couldn't say how it happened).
Is there something to verify to understand what's wrong?
Any idea what happened?
Old 17th November 2005, 09:47 AM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Does the volume of the hum change when you turn the volume pot up or down?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 17th November 2005, 10:10 AM   #3
No, not at all.
Old 17th November 2005, 12:41 PM   #4
youyoung21147 is offline youyoung21147  France
Send a message via MSN to youyoung21147
I got this problem and it came from a desoldered capacitor on the PSU. check them it could just be that
Old 17th November 2005, 12:42 PM   #5
Seems that I've inverted signal IN and signal ground!
Is the chip ruined ?
Old 17th November 2005, 05:07 PM   #6
pinkmouse's Avatar
Unlikely, they are quite robust.
Old 17th November 2005, 05:27 PM   #7
If you get hum on the speakers it means that it is still working !
4780 producing only hum: help needed!Hide this!Advertise here!
wich school is the best for producing ? hectik Everything Else 2 27th June 2005 08:00 AM
c3g producing sparks garbage Tubes / Valves 2 11th April 2005 04:03 AM
Tool for producing an LCR network that = a speaker+box? CeramicMan Multi-Way 2 27th May 2004 03:39 AM
