My First Power Amp
My First Power Amp
Old 17th November 2005, 03:46 AM   #1
Wyloch is offline Wyloch  United States
Default My First Power Amp
Okay, folks - done with headphone amps and interconnects - I want to build something to power my Klipsch RF-3s. Currently using a Carver m500t, but heard that it's a coloring amp.
I have this in mind:
http://sound.westhost.com/project19.htm
I want to build four, so that I can biamp each speaker. My reasoning for this is so that I can get more volume for less work, and therefore produce less heat, and prevent the built-in protection circuitry from kicking in.
Questions:
1) What is the SIM? Can I just neglect it and R8 and R9?
2) Are F1 and F2 fuses?
3) C5,6,6 and 8 appear to be polar capacitors - what type?
4) How to I provide +-35 V using a standard 120V wall oulet?
All the guides I see talk about PCBs. I don't want to use one; I want to come up with my own original board layout, because that's half the fun of the hobby to me.
Oh, and one more question:
5) Is this a good project?? I'm okay spending about $300 for the whole thing, even before casing options.
Old 17th November 2005, 03:56 AM   #2
Ah I see - I need a power supply - like this one?
http://stiftsbogtrykkeriet.dk/SiDown...3875/GAINC.pdf
Old 17th November 2005, 07:26 AM   #3
bsrawat is offline bsrawat  United States
Send a message via Yahoo to bsrawat
Default Re: My First Power Amp
Questions:
Dear,
+- 35v may be obtained by a step down transformer having current capacity of around 5-8 amps (if required) with bridge rectifier or 35-0-35v ac (sec.) with two diodes(unregulated) and a filter component of 7800mfd and an inductor. This will give you a good +- DC output from an intput of 120 v ac to power you amp
bsrawat.
Old 17th November 2005, 07:44 AM   #4
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
You'll spend a lot less + get lots of help around here if you pick up a kit from http://www.chipamp.com.
My First Power AmpHide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 08:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
Copyright ©1999-2017 diyAudio
