| Chip Amps Amplifiers based on integrated circuits |
#81 |
Thanks! It is an Omron G2R-1-E 6V, I do not know if it works, I hope to test the supply later today...
They must have been holy chips or something - Pedro |
#82 |
Thanks!
I need to order some parts from Conrad but didn't had the time yet to see which type would fit on the PCB. Any other stuff that I can order from Conrad for this little amp? Regards |
#83 | |
506354 6V trafo 5VA 508063 relais 472662 1000u 63V 472654 470u 63V 472409 2200u 16V 424854 200k trimmer 424803 4k7 trimmer This is what I ordered from Conrad. Those capacitors and trimmers fit perfectly. Just make sure you keep the voltage under 2*63V.
#84 |
Dankjewel
#85 |
Hanzwillem
For the relais, is it possible that I need the 508128-06 instead of the one you propose. The one you mention has only 1 switching contact and we are in need of two (both AC1 & AC2 will be switched) I also will need 100V capacitors to be on the save side with the transformer I have. (22+22)x1,414= ±63V Regards |
#86 | |
That would have been a few blown fuses for me...
#87 |
Hanzwillem, are you leaving a hole in the cover of the case for the tube?
Cheers Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
#88 | |
#89 |
My wife wouldn't allow it
I put my project on idle while waiting the correct relay. Cheers Andrea
#90 |
Franz, Zang
A small question. The input resistor behind the potmeter; the schematic says 3K9 but the partslist says 3K3. Does this value matters all that much? Where is digi01 by the way? Regards |
| HV supply please comment before building | bembel | Tubes / Valves | 8 | 5th December 2006 10:16 AM |
| VBITNGC group buy | digi01 | Group Buys | 47 | 28th February 2006 07:21 AM |
| My Building Plans: Comment and suggest... | asgorath | Chip Amps | 13 | 9th July 2005 06:41 AM |
| VBITNGC integraded PC? | bjefferys | Chip Amps | 1 | 30th March 2005 01:27 AM |
| Page generated in 0.10464 seconds (79.24% PHP - 20.76% MySQL) with 11 queries |
