Old 24th November 2006, 02:21 PM   #431
loek is offline loek  Netherlands
Default LED
I found that my relay voltage was a little high: 8,5V for a 5V type so i added a LED in series with the relais.
Nice red if the circuit is on...
Old 24th November 2006, 03:07 PM   #432
CarlosT is offline CarlosT  United States
Do LEDs introduce noise?
Old 24th November 2006, 04:56 PM   #433
Franz G is offline Franz G  Switzerland
Franz G's Avatar
In this situation, driven by the filament/relay voltage: No!
Franz
Old 24th November 2006, 06:08 PM   #434
wim is offline wim  Netherlands
Default Re: LED
Good point Loek,
I shall measure my relais voltage too, and adjust it
if necessary.
What i found in this design and also in the previous design (from Digi and Franz), is that turning the pot that increase or decrease the delaytime of the relais is not working properly; whatever the position of the pot is, the time stays the same (about 25 seconds). For me its perfect, but why does't work this pot? What is your experience Loek, or someone else?
I have the VBITNGC working, and the first experiences are good. When time comes i will connect it to my regular audio system. I will report the results. I have the earlyer system (Digi and Franz) playing for about 9 months, ans i like the sound!
Succes building and playing to all of you!
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn.
Old 24th November 2006, 06:20 PM   #435
Default whatever the position of the pot is
Hi Wim, i did not have a pot that size yet so i used a 47k resistor and with C17=100uF the delay is 30 seconds. so i keep it this way.
I can short the 47 k and count...
edit:
Did it and then it is 25 seconds, so it works as it would be...
Loek
Old 24th November 2006, 06:54 PM   #436
Thanks for your info Loek, I leave it also as it is, good to me.
Old 24th November 2006, 07:30 PM   #437
Default Re: exactly the same relais
Hi Wim, indeed unbelievable, but i know a very nice supplier in the neighbourhood.
I connected the transformer for the heatingsupply, C20 is 1uF poly, R9 is 120 ohm and adjusted the output to 6,3 V.
It works! I placed the tube and inspected the voltage with a scope and found that the regulator is oscillating.
So i removed the 1uF and placed a 10uF elco: clean picture.
Display 100mV and 1uSec/div.
That are my findings.
Loek
This is very interesting. Have anyone else who finished this amp found this or something else? Actually, who has it really finished? Franz? Digi? GeWa? If you guys finished it, post some jpegs here!
Old 24th November 2006, 07:59 PM   #438
There is another strange thing i found with this design (the first desing from Franz and Digi and the second design too): With no source connected there is a loud brrrrrrrr in the speakers. When i connect a source (CD-player) there is no brrrrrrr. I can live with it, but is is strange.
Old 24th November 2006, 09:22 PM   #439
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
Anyone figured out where the schematic file is?
(I don't mean to sound annoying...but I really want to make one of these because I think that they will sound amazing!)
Old 24th November 2006, 10:09 PM   #440
Default Anyone figured out where the schematic file is?
Not so difficult if you check the last posts: post 420.
Wim, normally there has to be a resistor from grid to ground.
If you leave the input open there is no "leaking resistor " for the grid.
You can connect a resistor (1Meg) parr. to the inputconnector.
Maybe this will help.
good luck, Loek
HV supply please comment before building bembel Tubes / Valves 8 5th December 2006 10:16 AM
VBITNGC group buy digi01 Group Buys 47 28th February 2006 07:21 AM
My Building Plans: Comment and suggest... asgorath Chip Amps 13 9th July 2005 06:41 AM
VBITNGC integraded PC? bjefferys Chip Amps 1 30th March 2005 01:27 AM
Page generated in 0.23723 seconds (37.89% PHP - 62.11% MySQL) with 11 queries
