Old 16th November 2005, 05:31 AM   #31
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
the third assembly is psu.
sch is here:http://www.diyaudio.com/forums/showt...698#post765698
part list is here:http://www.diyaudio.com/forums/showt...311#post748311
the attached is the modified assembly of psu.
attention:the ne555 chip should be set up in reverse station!
Old 16th November 2005, 07:55 AM   #32
Franz G is offline Franz G  Switzerland
Franz G's Avatar
For the tube which needs something between 35-0-35 & 100-0-100 @ 15+ mA or so...
Please, don't confuse people, this statement is completely wrong!
Again: for the tubes anode voltage, a single 35V to 45V secondary is needed. Please look at the schematics!
We use a voltage doubler circuit, so called Greinacher circuit.
Franz
Old 16th November 2005, 11:35 AM   #33
frugal-phile(tm)
planet10's Avatar
Completely wrong? I could have been clearer...
From the schematic you have plus/minus 45-63VDC. The original used +/- 35VDC and we talked with supplies north of 1/-100.
True that the "official" board uses a doubler, but those that don't want to use a doubler it is a perfectly valid (some would say better) approach to use a bridge & a dual secondary trafo.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th November 2005, 02:21 PM   #34
wim is offline wim  Netherlands
Franz (or Zang), can the diodes D9+D10 (1A 1XYS 1-16D in the BOM) be replaced by the more common types 1N4007?
Thanks.
Dave, i do not understand your point. A simple and common low current trafo of 20-0-20 VAC is good for the job, with both windings in serie. What you get is 2*20VAC = 40VAC, fine in the range Franz told us.
Or do you mean something else? My English is not perfect you know.
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn.
Old 16th November 2005, 02:45 PM   #35
Franz G's Avatar
Of course, it will work with 1n4007.
Franz
Old 16th November 2005, 03:17 PM   #36
Thanks a lot Franz.
Old 16th November 2005, 05:09 PM   #37
Franz, what is the resistor on the photo in post 31, on the backside of the PCB? Is that resistor named in the BOM or is it a fix, or additional?
And do you mean in also post 31 that the IC must by placed 180 degrees rotated than the PCB says?
Thanks again, and sorry for all my questions.
Old 16th November 2005, 05:40 PM   #38
Franz G's Avatar
Wim
Yes, the silk print is showing the NE555 in the wrong orientation.
About the resistor under the board: wait the answer from Zang. It seems, as he did not insert the trimmer pot and the resistor in series and replaced them by a fixed value under the board.
I am sorry about the errors on the silk print! I checked many times the solder side, but not enough the parts side. And I did not use a PSU board from Zang up to now.
Franz
Old 16th November 2005, 06:37 PM   #39
Thanks again Franz.
For the resistor at the bottom off the PCB i will wait as you told (mayby if i place the trimmer pot the resistor is not nessesury).
I (and all other builders i hope) will place the NE555 at 180 degrees turned around.
Don't wory about the mistakes. if we have a good communication on this forum it will be no problem, in fact it is part of the hobby!.
Till later,
Wim
Old 16th November 2005, 08:11 PM   #40
Sorry, but here i am again.
Franz, looking at your recently posted picture of the Murs on the PSU board: In the first place you changed de Murs and the C's (but thats no problem), but what is a problem I.M.O, you mounted all the Murs wrong. (cathode = anode and anode is cathode).
Please correct me if i am wrong, but i am pretty sure of it.
Best way to see it is to follow the schematic off the PSU and look good to the mountingway on your board.
If you lay down a Mur on your desk with the black plastic side in front of you, the left connectionwire is the cathode.
Hope to hear from you about it.
Till later,
Wim
HV supply please comment before building bembel Tubes / Valves 8 5th December 2006 10:16 AM
VBITNGC group buy digi01 Group Buys 47 28th February 2006 07:21 AM
My Building Plans: Comment and suggest... asgorath Chip Amps 13 9th July 2005 06:41 AM
VBITNGC integraded PC? bjefferys Chip Amps 1 30th March 2005 01:27 AM
Page generated in 0.11015 seconds (78.57% PHP - 21.43% MySQL) with 11 queries
