| Chip Amps Amplifiers based on integrated circuits |
#21 |
Anybody here that has a source for a 45V-0-45V / 5-10VA toroid transformer.
The lowest VA rating I can find with those secondaries is 160VA, and that is a bit overkill I figure? Regards |
#22 | |
You need only one winding of ~45 VAC. So you can use a tranny ranging 18-0-18 to 22-0-22. These should be no problem to find in that VA range. cheers. (please correct me if I got confused between my projects )
They must have been holy chips or something - Pedro |
#23 | |
What's even worse, I have two 22V-0-22V / 35VA trannies in my goodies cupboard. I really feel stupid now Thanks for the hint Hanzwillem Regards |
#24 | |
BTW: I use one single torroid, about 165VA. It is including 14.8-0-14.8V (LM3875), 17.6 and 19.8 in series for the anode voltage. Then I added some windings for the 6V part (about 60 windings in my case, just try 20 windings, measure under load and calculate the needed windings, its linear). It is a good idea, when you use the small case and relatively small heathsinks, not to use too high voltage and to much gain for the LM3875. Franz |
#25 | |
Yes,there are silk layer missed of bridge and delay parts,I am so sorry for all troubles.I will release a 'PATH' for the psu board soon.please keep it for a while. to wim,sorry for delay.because I couldn't surf net during weekend. P.S. the attached photo is the connection of 'T' network. |
#26 | |
yeah I have the same problem to find a proper transformer.I use a 20VA 8VAC wallwart directly powered the tube filaments and delay.A step-up transformer(200VAC to 24VAC,in reverse) converted the 8VAC to about 73VAC. Zang |
#27 |
Mayby i missed something, but what is the need for a 45-0-45 VAC trafo? I assume you will put the windings paralel to get about 62 VDC after rectification?
Why not a trafo between 18-0-18 VAC and 22-0-22 VAC, and put the windings in serie? These trafo's are common with a much lower VA rate. Or do i mis something?
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn. |
#28 |
No Wim, you got the point exactly. I think I'm the nitwit who started this confusion. I was under the impression that a 45-0-45 trafo was needed. Look at post #23.
Sorry for all this Cheers |
#29 |
Okee GeWa, now you can choose a suiteble trafo. i take 18-0-18 VAC. RS Components have them in very small VA ratings (cheep and compact). Succes.
#30 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| HV supply please comment before building | bembel | Tubes / Valves | 8 | 5th December 2006 11:16 AM |
| VBITNGC group buy | digi01 | Group Buys | 47 | 28th February 2006 08:21 AM |
| My Building Plans: Comment and suggest... | asgorath | Chip Amps | 13 | 9th July 2005 07:41 AM |
| VBITNGC integraded PC? | bjefferys | Chip Amps | 1 | 30th March 2005 02:27 AM |
| Page generated in 0.14605 seconds (68.90% PHP - 31.10% MySQL) with 11 queries |
