Old 10th November 2005, 06:29 AM   #11
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
here is the connections of buffer to amp.
P.S.
to Evilsizer,I have got a small enclosure from franz,will show the completed amp pic soon.
Zang
Old 10th November 2005, 07:58 AM   #12
Franz G is offline Franz G  Switzerland
Franz G's Avatar
I am waiting for a cad drawing from my supplier and an offer for ready prepared boxes.
As soon as I get the drawing, I will post it here.
On the other hand, it should be quite easy to build the own case out of two aluminium sheets.
Franz
Old 10th November 2005, 12:10 PM   #13
wim is offline wim  Netherlands
Zang, witch of the posted PSU schematics can be used? There are different types on the forum. I assume the one from Franz d.d. 6 oktober 2005 is de right one?
And why in the BOM 2 trafo's from 2x18 VAC?
Can we see pictures from a build PSU too?
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn.
Old 11th November 2005, 11:27 AM   #14
Hanzwillem's Avatar
There seems to be an error in the silkscreen of the PSU board.
I suspect D1,D2,D3 to be printed the wrong way. I don't see this work as a proper bridge as it is drawn at the moment...
They must have been holy chips or something - Pedro
Old 11th November 2005, 02:06 PM   #15
Nordic is offline Nordic  South Africa
Nordic's Avatar
I still can't wait to get my hands on one of these, the only valve driven item I have is an old valve radio my grandfather build. Although I know the valve sound from band equipment like Fender bass amps etc... vely nice
Old 12th November 2005, 01:30 PM   #16
Andypairo's Avatar
Got my boards today, they seem to be well done.
Maybe the holes for the tube socket could have been bigger. I had a hard time fitting mine into them.
Will inform of the progress.
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 12th November 2005, 02:36 PM   #17
Hanzwillem's Avatar
I used a drill to make the them slightly larger. There are more holes which weren't as expected. I had to bend the leads of my Elna duorex to make them fit the PSU board.
Old 12th November 2005, 03:49 PM   #18
I had the same problems, fitting the tubesocket on the PCB.
Hanzwillem, strange there is no comment on your post about the wrong PS PCB layout. I posted some other questions, but received also no answers.
Are Franz and Zang together on a lazy hollyday
Old 13th November 2005, 09:38 AM   #19
Franz G's Avatar
Sorry, I spend my weekend with my little daughter. Just in a hurry:
It seems in fact to be a mistake in the silk screen of the psu board. So, think about a correct bridge topology, before you solder the diodes!
I think, "my" schematic and the schematic from Zang are adequate. Two corrections: the filament voltage is +6.3VDC and ground (not -6.3VDC) and the 85VAC are too high to use with 63V electrolytics.
http://www.diyaudio.com/forums/showt...303#post753303
About the tranny:
You could use one, two or three trannies. Important is to have:
- 2 x 20VAC about 165VA (you are free to do your own gain calculation, depending on the available tranny as mentionned in the LM3875 datasheet)
- 6 to 8VAC 10VA (filament 6.3VDC and NE555/relay circuit)
- 35 to 45VAC 5VA min (anode voltage)
Franz
BTW:
Nice PSU simulation, to simulate the available trannies: Search for Duncans Amp Tools, PSU simulator. It is free.
Old 13th November 2005, 10:35 AM   #20
Thanks a lot for your answers Franz!
HV supply please comment before building bembel Tubes / Valves 8 5th December 2006 11:16 AM
VBITNGC group buy digi01 Group Buys 47 28th February 2006 08:21 AM
My Building Plans: Comment and suggest... asgorath Chip Amps 13 9th July 2005 07:41 AM
VBITNGC integraded PC? bjefferys Chip Amps 1 30th March 2005 02:27 AM
Page generated in 0.31891 seconds (32.16% PHP - 67.84% MySQL) with 11 queries
