[LM3886] Best resistor value for mute ? [LM3886] Best resistor value for mute ? - Page 3 - diyAudio
Old 12th November 2005, 09:44 PM   #21
youyoung21147 is offline youyoung21147  France
Send a message via MSN to youyoung21147
Just made my LM4780 amp run tonight, and it has absolutely silent turn-on and off transcients. I measured the transcients with a DMM : there is a 60mV peak when turning off, and nothing when turning on, so there is nothing audible.
They say the mute resistor should be 10k, I used 9.1k so I'm sure the mute pin will draw its 0.5mA from the -V rail
I assume those 0.5mA are just supervised by a mute circuit, and changing the resistor value won't affect it as long as this current is just "witnessing" that the amp shouldn't be muted.
Maybe the transcients one may experience are due to the caps on the feedback network ? They may store some energy and send it back when the circuit is powering down ?
Old 12th November 2005, 10:00 PM   #22
carlosfm is offline carlosfm  Portugal
Banned
I don't think so.
I said that the LM3886/4780 doesn't need the muting cap, and it sure doesn't, as you concluded too.
P-A has extra op-amps on board (which can generate turn-on transients), and he probably doesn't have experience with these LM chips alone.
Old 14th November 2005, 08:05 AM   #23
XELB is offline XELB  Portugal
Hey Guys.
I lost this weekend trying to find the right resistor value for the mute!
After trying a few resistors I tried the -Vcc connected directly to the mute pin
And yes, this is another step forward in the LM3886 implementation
This chip is playing like this since Saturday and, till now, it's running fantastic.
( I think that the LM3886 have some sort of protection that allow him to run like this )
Setup:
1x LM3886 p/ channel
20.000uF p/ rail
1200VA trafo ( [-Vcc] + [+Vcc] = 94V )
If you want power you must add control
Old 14th November 2005, 11:49 AM   #24
Tazzy is offline Tazzy
Send a message via MSN to Tazzy
What value did you prefer in the end?
Old 14th November 2005, 01:02 PM   #25
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Short circuit so it seems
I think 10k is good if you don't have any special requirements.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 14th November 2005, 02:12 PM   #26
There's no short circuit
The LM3886 must have some sort of protection and the mute stays OFF
With this implementation the current inside the chip doesn't depend of the mute resistor.
Give it a try, wait 30m/1H to heat the chip and then listen
BTW, the LM3886 runs much better when is hot!
The right(not to big and not to small) heatsink could improve sound dynamics...
Old 14th November 2005, 07:14 PM   #27
Banned
There must be an internal protection for guys like you.
Old 14th November 2005, 08:38 PM   #28
And it plays very well, just like guys like me like
It plays 3xLike LOL
Why don't you try
It's safe, but if you are affraid of burning one LM3886, I have an extra chip
Old 14th November 2005, 09:07 PM   #29
peranders's Avatar
XELB, could you measure the current you have through the MUTE pin and report back? What supply voltage do you have?
Old 14th November 2005, 09:34 PM   #30
As I told before, the LM3886 is running at max. specs |+V|+|-V| = 94V
Are you affraid of testing without the resistor ?
heheheheheh
[LM3886] Best resistor value for mute ?Hide this!Advertise here!
lm3886 no mute rtill Chip Amps 21 29th August 2009 05:43 AM
Mute resistor value Lico Chip Amps 3 4th February 2005 04:40 PM
LM3886 Mute richie00boy Chip Amps 6 18th August 2004 11:26 AM
lm3886 mute LED blabley Solid State 1 30th May 2002 05:51 AM
Copyright ©1999-2017 diyAudio
