| Chip Amps Amplifiers based on integrated circuits |
After 3 month I've finished my PGA2310 based preamp. Some technical data :
Digital part : - PIC 16F628 running at 4MHz for volume and mute control and driving LCD display - PIC 12F675 running at 1MHz for input selector - 16x2 LCD with backlite - PGA 2310 Analog part is based on the schematic from This page . The only difference is that I used OPA2134 for input and output buffer. Here is the front view
Some are born with more and some born with less so don't take for granted the life we've been blessed it's hard to understand thet we're only a guest and each one of us shall be put to life's test. |
#2 |
This is the rear view
#3 |
And finaly the inside view. I know is a mess inside, but I will optimize the wiring. I must say that the preamp is dead quiet and it souds very smooth and at the same time very fast and well determinated.
#4 |
Wow wow and wow, feel free to share more...
wassup with the selector LEDs though, seems all are lit but one? |
#5 |
Banned
Hi bostjancek,
Good job, looks good. One thing: those unshielded cables should not be close to each other, it creates crosstalk. Most critical I see there is the output cables, separate them widely, or use shielded cables there, they are also close to the PSU. The input buffer could left out, or just buffering the tape outputs. |
#6 |
Huudooo ...
Tole si pa dobro naredil )))Bi te prosil (ce hoces) da mi posljes svoj kontaktni email na stabist@email.si ker bi te pobaral par stvari (se mi par PGAjev ze dve leti valja pa caka) Just explaining to Bostjan, that the first impression of his preamp is and am very interested in some more informations ...A real nice work! |
#7 |
To Nordic - the Led which is not ON shows the input which is active. Yes I know is strange but this is caused because of the relais which are normaly closed (I have it - so I used them). This setup is only temporary. In the future I plan to use a Burr-Brown MPC508 which are 8 channel single ended analog multiplexer (I've got samples
).Cheers
#8 |
To carlosfm - the unshielded cables (twisted pair from CAT-5 cable) which are close together are used for leds in front pannel and for buttons. The twisted pairs for input and output - I'm planning to change them with shielded cable as soon I will make a new input selector with MPC508. I'm also planning to change the main board because I will use just 1 PIC micro (16F76 which have 28 pins) for all digital controls. I will also add the support for RC5 IR remote control.
Cheers
#9 |
Stabist ni problema sem ti poslal e-mail.
Stabist I've sand you the e-mail. Cheers
#10 | |
Very Nice Job! I've been working on a very similar project for some time now, and have finally gathered all of the necessary parts. Your project has just given me the inspriateion to finish it...I hope. What did you use to program the PICS...would you mind sharing the code with us? Thanks. G.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
| Finished Car Amplifier schematic + PCB based on Kenwood KAC-716 | Risto80 | Car Audio | 154 | 25th August 2011 03:18 AM |
| Finished amp (based on TA2024) | maurycy | Class D | 0 | 21st January 2009 01:24 PM |
| ThermalTrak based Amplifier finished | Arius | Solid State | 23 | 23rd April 2008 11:24 PM |
| CPLD based DIY Pre-Amp and display Kit (PGA2310) | solomon2773 | Swap Meet | 0 | 3rd June 2005 05:12 AM |
| Burr Brown PGA2310 based Preamplifier for sale | krishu | Swap Meet | 0 | 15th June 2004 03:23 PM |
| Page generated in 0.12100 seconds (74.62% PHP - 25.38% MySQL) with 11 queries |
