Does anyone have experiences with the LT1210?
Old 8th November 2005, 12:06 PM   #1
Dominique is offline Dominique  France
Question Does anyone have experiences with the LT1210?
Hello,
I'd like to build a quick and easy amp, that doesn't need to be high-power.
As the specs look very good, I thought about using 2 LT1210 per channel. They have better specs than the commonly used National chips, and two should give 16W at 4 Ohms. The LT1210 is a 1,1A 35MHz current-feedback 7-pin TO-220 op-amp from Linear Technology.
Did anyone already use it?
Dominique
Old 14th April 2008, 09:08 AM   #2
err_smart is offline err_smart  Moldova
http://sound.datagor.ru/a-ti-uzhe-um...t1210--r65.htm
http://sound.datagor.ru/ms33079-lt12...haila--r17.htm
Old 14th April 2008, 04:43 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Using the Linear Tech model, and just using the LT1210 to drive an output the THD% is about zero.
If you are going to wrap the output about a couple of transistors then the THD% will be a lot higher --
I would like to see how the LT1210 compares with the LME49600.
Old 14th April 2008, 05:40 PM   #4
jcx is offline jcx  United States
I have built a single channel prototype using LT1210 (with V gain) as a power "buffer" inside a high quality fet input op amp feedback loop
Walt Jung describes the advantages of these multiloop topologies
you will probably need a "Zobel" series L || R (~ 0.5-1 uH ||~ 10 Ohm or appropriate sized lossy ferrite EMI "bead" ) at the output to keep the cfa LT1210 from oscillating with large capacitive loads - like long speaker cables
also 1 A max current into 4 Ohms is 16 W peak/or DC, only 8 Wrms for music; 8 Ohms is a better match to the LT1210 output I,V capabilities
Old 15th April 2008, 01:07 AM   #5
oops messed up the math, (1 A)^2 * 4 Ohms = 4 W peak/DC => 2 Wrms
more power within the V swing capability of the LT1210 requires paralleling for higher current output - which in turn requires some current sharing arrangement - like small value power reisitors in the outputs
2x || LT1210 could put 8 Wrms into 4 Ohms
3x || LT1210 could put 18 Wrms into 4 Ohms
more than 3x || will run out of Vswing capability with 4 Ohm loads
Does anyone have experiences with the LT1210?Hide this!Advertise here!
Any experiences with AD8671/2/4? Popolvár Solid State 7 23rd December 2011 02:29 AM
P3B experiences? Colescuttle Solid State 7 12th May 2011 12:23 AM
Please check my chipamp with 2 x LT1210 Dominique Chip Amps 15 6th January 2008 01:25 AM
OP AMP EXPERIENCES and HOW TO tawn10 Analog Line Level 59 5th June 2007 04:14 AM
Experiences With F200A? was ist los? Multi-Way 1 27th July 2004 08:33 AM
