How inexpensive can you build a small 6-ch amp?
Old 5th November 2005, 07:20 AM   #1
mazeroth is offline mazeroth  United States
Default How inexpensive can you build a small 6-ch amp?
I'm looking to learn how to build amps and was wondering how much it would run to build a very small 6 channel amp for my computer's active speaker setup? I'm guessing I won't need any more than 5-10wpc, since I'll be about a meter away at most from the speakers.
Any information or links is GREATLY appreciated!
Old 5th November 2005, 08:12 AM   #2
joensd is offline joensd  Germany
You could have a look at nationals calculator for "estimations" on what youŽd need for rail voltage for specific loads.
For building a GC I like Nuuks site very much. Very well put together.
The cost determining factor will be transformer, chassis, sockets
(besides the amps/kits themselves) so keep your eyes open for anything cheap.
What about transformers for halogen lights?
Usually theŽre dead cheap and would easily get you into the 10W ballpark.
http://www.national.com/appinfo/audi...gn_Guide13.xls
http://myweb.tiscali.co.uk/nuukspot/...loneindex.html
For the application a LM3875 would absolutely suffice, also with 4ohm loads due to the low rail voltages.
If you want it cheap do it P2P or get one of the "known" kits around here which are quite cheap as well. (got mine from BrianGT/Peter Daniel, as sourcing all the parts would have been more expensive)
jens
Old 5th November 2005, 08:23 AM   #3
thespeakerguy is offline thespeakerguy
Send a message via Yahoo to thespeakerguy
Consider Class D Amplifiers.
For example, operating off a laptop type power supply, such as 16V 4A from an IBM thinkpad, you can do 10W into 8 ohms into 6 channels. Of course, not all channels would do this at the same time, so each channel can acheive reasonable power well within the power supply's capability.
One approach, 3 pieces of MAX9741, for the 6 speakers, the a single MAX9708 in mono mode for a subwoofer.
Total solution would easily fit on a 3"x5", assuming small 3.5mm stereo jack inputs, and small speaker terminals, not binding posts.
No heatsinks required
Old 5th November 2005, 10:14 AM   #4
sagarverma is offline sagarverma  India
sagarverma's Avatar
bridged lm358 for each channel
so u get 6 channels of 2w each(rms).net power is 12w rms.sufficient enough,cheap too.low cost of components,inexpensive heatsinks,low cost transformer,good quality sound output.
cost estimate<$10.
google shows many links for above application
Old 5th November 2005, 01:24 PM   #5
lohk is offline lohk  Europe
lohk's Avatar
3 x LM1876
/lohk/
Old 6th November 2005, 02:06 AM   #6
Gcollier is offline Gcollier  Canada
Could try something like this! I used SMD resistors to cut down on the size as much as possible. The feedback resistor is just behind the pins on the LM1875 (again a 1206 SMD package). I designed a small little PSU to go along with these, nothing fancy a brige rectifier and a few caps. I intend on using them in a small speaker syster for my office at work, I plan on mounting them in a small extruded aluminum enclosure along with the transformer.
G.
If you take something apart and put it back together again enough times, eventually you will have two of them.
Old 6th November 2005, 02:14 PM   #7
sagarverma's Avatar
lm358 fits your demands
Old 6th November 2005, 03:32 PM   #8
carlosfm is offline carlosfm  Portugal
Banned
2xLM4781
Old 6th November 2005, 04:08 PM   #9
sagarverma's Avatar
hey
grave mistake
its lm386 not 358.
highly regretted
Old 6th November 2005, 04:48 PM   #10
ocool_15 is offline ocool_15  Canada
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
[QUOTE]Originally posted by sagarverma
[B]hey
grave mistake
lm358 is opamp dual op i think I was rather confused by that statement. Everyones got some lm386s though
How inexpensive can you build a small 6-ch amp?Hide this!Advertise here!
[noob] Looking to build a really, really small sub Lindell Subwoofers 18 13th November 2007 04:16 PM
Small inexpensive subwoofer amp imperfectcircle Chip Amps 1 8th January 2007 11:15 PM
Small, Inexpensive High Quality Film and Foil Caps dsavitsk Parts 5 7th February 2006 02:25 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
6 clean, small, inexpensive channels? Jon Lane Solid State 3 1st March 2004 12:46 AM
