Netlist said:There’s a good chance that your test circuit will go up in smoke just as the amplifier did. Looking at the ‘Typical Application and Test Circuit’ in the datasheet there are quite some components to loose as well. On the other hand, this might probably be the simplest schematic to build as a test circuit and in the meantime you have build an amplifier.
/Hugo
yeah u r true but the whole idea is to avoid fake b4 hand on the spot and blacklist the shop.what use u pay a hell,burn the circuit and your blood!!
