| Chip Amps Amplifiers based on integrated circuits |
Hi! I posted photo of my new LM4780 amp, its sounding very good, but I hear in speakers when a light switch in my flat is turned on or off - when somewhere an electric arc is started... I dont know how filter it out...
Thx for any help
#2 |
Some people recommended installing input shunt capacitor: 300pF or similar.
You might also try to improve grounds in your system.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Used Cc across the pins (220pF from memory) on a 3886 to kill off the blip from aquarium fluoro lights that worked well. A stereo setup would have one across pins:
-IN A +IN A another across: +IN B -IN B I think... best wait for verification. Details on page's 1, 7 & 8 in the datasheet. |
#4 |
try to shield and ground your case properly, with iron plates for example. The cap across the input pins is a simpler solution and works too.
#5 |
the bypass capacitors on the V+ and V- pins (100nF ceramic + 10uF) will help a lot. Also -- you can use ferrite beads on the input lines -- most likely you are picking up a transient on the power supply lines --
you can also box up the LM4780 (but not the heatsink) in a box made of Printed circuit material -- just solder up the sides. |
#6 | |
Why not the heatsink ? I assume it must also be grounded if you want to "enclose" the chip in a shielded area. Or do you mean keeping it out, grounded properly, to avoid heat issues ? |
#7 | |
| Problem with LM4780 | Cyberzim | Chip Amps | 14 | 24th January 2010 05:40 PM |
| LM4780 problem - need Help | AndriyOL | Chip Amps | 56 | 29th January 2009 07:58 PM |
| Problem with LM4780 | Dielkius | Chip Amps | 8 | 13th January 2007 01:06 PM |
| LM4780 problem | Faber | Chip Amps | 8 | 16th August 2004 04:39 PM |
| Page generated in 0.10599 seconds (75.04% PHP - 24.96% MySQL) with 10 queries |
